4r100 swap - Ford Powerstroke Diesel Forum
post #1 of 12 Old 11-16-2008, 06:37 PM Thread Starter
ZachBoyer's Avatar
4r100 swap
So what does it take to swap the 4r100 I believe it is(the newer trannys in the 99-03 7.3) into our obs?
2005 F250 6.0 King Ranch Crew Cab Short Bed 4X4
-MODS-
4" Turbo Back Straight Pipe
Sinister EGR Delete
Sinister Coolant Filter
Cat EC-1 Coolant
ZachBoyer is offline
post #2 of 12 Old 11-17-2008, 09:19 AM
z250kid's Avatar
pretty much the same thing the only differnce i know is it has a drain plug on the pan. lol idk other than that
1996 F350 4x4 Powerstroke Diesel
Afe Stage 2
3 Inch Downpipe,Cat-Delete,90 degree elbow(ss)
Diy Exhust Brake
Hpx Crossover
z250kid is offline
post #3 of 12 Old 11-18-2008, 06:47 PM Thread Starter
ZachBoyer's Avatar
Thanks BUMP for any more information
-MODS-
Sinister EGR Delete
Cat EC-1 Coolant
post #4 of 12 Old 11-18-2008, 06:52 PM
lifetime member
i think the 4r100 is just a heavy duty version of the e40d with overdrive added to it.
january 2003 6.0 F-350 Lariat 4x4 cc with 08 long bed. recon cab and mirror lenses, torqueshift(reman on 9-03-09) with three disc billet convertor(500 rpm lowered stall speed),mag-hytec deep tranny pan,, 8" fabtech lift w/ 37" iroc super swampers on helos,pro comp ladder bars, custom sct x3 with tunes by eric @ innovative diesel, boost and pyro,edge insight, afe, 4" straight piped, ARP headstuds, banks intercooler & high ram intake. engine mods & maintenance by first coast diesel performance.
nsrchofpwr is offline
post #5 of 12 Old 11-18-2008, 07:32 PM
Er.. e4od means Electronic 4-speed Over Drive. the 4r100 is very similar on the outside, but I don't know about whether or not it will plug right in as a replacement. They have the same pan. filter, valve body, tail shaft housing, etc. I don't know about the internal parts. Also, some body mentioned that the 4r100 has a drain plug, but the e4od does not. This is not true. If your truck came with a "deep pan" (both e4od and 4r100)it has a drain, if you got the shallow pan you don't get one. the 4r100 also comes with a shallow pan on some trucks.
Eli Benson - EMT, Ambulance Mechanic
'08 F350 Dually KR - Spartan'd
'07 F250 CC SB 4x4 XLT - SCT /w Innovative Tunes
4 '09 & '10 E350 6.0l ambulances
1 '08 Duramax 6.6 (LMM) van ambulance
elibenson is offline
post #6 of 12 Old 11-18-2008, 07:35 PM
lifetime member
i am getting tired and have no idea why i put "over drive added to it". i do know better, but i guess not tonight. lol
post #7 of 12 Old 11-18-2008, 07:40 PM
PMR = JUNK
Jake's Avatar
Quoted: 4 Post(s)
E4OD is an overdrive trans I believe. E=Electronic, 4=4 speed, OD=OverDrive.
BPS President
2000 F-250, forged rods, 38r turbo, BTS trans, hutch mod, TW tuning and Bad Night Special 50 horse Caterpillar injectors
Originally Posted by alberta 7.3 View Post
Yeah, I'd probably feel a bit drained after firing twice in rapid succession.
Jake is offline
post #8 of 12 Old 11-18-2008, 07:41 PM
PMR = JUNK
Jake's Avatar
Quoted: 4 Post(s)
I'm slow, you corrected yourself before i did, lol.
BPS President
Jake is offline
post #9 of 12 Old 11-18-2008, 10:27 PM Thread Starter
ZachBoyer's Avatar
so i wounder if I can just drop a 4r100 in with no mods??? a 4r100 has an extra gear doesnt it. Thats mainly why I want it if so
-MODS-
Sinister EGR Delete
Cat EC-1 Coolant
post #10 of 12 Old 11-19-2008, 03:25 PM
z250kid's Avatar
nah its a 4 speed with over drive just like the e4od
Afe Stage 2
Diy Exhust Brake
Hpx Crossover
z250kid is offline
