Ball Joints....PITA!!! - Ford Powerstroke Diesel Forum
post #1 of 14 Old 11-16-2008, 09:33 AM Thread Starter
Justin M's Avatar
Quoted: 2 Post(s)
I never dreamed in my mind that ball joints were such a PITA....Getting them off the truck was simple....but getting them out of the spindle...impossible even with the press i rented from Oreilly's...so gonna run the spindles over to the local axel and wheel place in the mornin...wish me luck there!
MINE - 1997 F-350 ZF5 XL
WIFES - 2006 F250 Lariat FX4
Justin M is offline
post #2 of 14 Old 11-16-2008, 09:35 AM
ford_trck's Avatar
Send a message via AIM to ford_trck
Did you use an impact on the press? If you did they should have come out
Early 99 F-350 CC LB 6-speed
Stock with mods
Originally Posted by CloverLeafFarm View Post
Hey Ross, after talking with you i did some research and seems like you chose the right path to go, i knew you were a super genius!
Ross
ford_trck is offline
post #3 of 14 Old 11-16-2008, 09:38 AM Thread Starter
Justin M's Avatar
Quoted: 2 Post(s)
The press was not a great press at all and my impact did not even budge them!
Justin M is offline
post #4 of 14 Old 11-16-2008, 10:33 AM
ford_trck's Avatar
Use the press impact them and when they don't move hit the head of the forcing screw with a BFH. If that doesn't work use heat.
Did you take out the snap rings?
Stock with mods
Ross
post #5 of 14 Old 11-16-2008, 10:43 AM
CompressionIgnitionAddict
99ildually's Avatar
I knocked mine out with a BFH, pressed them back in with a hydraulic press.
-Josh
Early 99 F-350 2wd DRW
6 Speed 4.10 rear
4 in turbo back muff delete
Intake Superchip & 4k mod
99ildually is offline
post #6 of 14 Old 11-16-2008, 01:08 PM Thread Starter
Justin M's Avatar
Quoted: 2 Post(s)
I took them to the Local NTB...they were the only place open on Sunday
Justin M is offline
post #7 of 14 Old 11-16-2008, 05:44 PM
badyota82's Avatar
I think my ball joints may be going bad, but not totally sure. What symptoms should I have. I have a popping noise coming from the front end sometimes when I turn, but don't know if its ball joints or bad bushings. Any Ideas??
badyota82 is offline
post #8 of 14 Old 11-18-2008, 01:49 PM
badyota82's Avatar
Does anyone have any ball joint advice?? What tell tale signs are there if they are going bad??
post #9 of 14 Old 11-18-2008, 01:54 PM
I am that hot
superxcrewfx4's Avatar
Loose steering, tires wearing unevenly, tires falling off the truck, you know the normal things hahaha
1999.5 Ford F-250 Powerstroke
7.3 Powerstroke Diesel
4" Turbo Back MBRP with 6" Tip Straight Piped!
DIY Intake
Isspro Gauges
Diesel Site Coolant Filter
TW 6 Position Chip
2.5 Inch Leveling Kit
305/75/16 Mickey Thompson MTZ's
239k and COUNTING!!!
superxcrewfx4 is offline
post #10 of 14 Old 11-18-2008, 01:56 PM
burmad69's Avatar
We have seen the ball joints get tight and you get memory steeer ya know it kinda goes where you point it and then loose ones that rattle all diesels do it its not just ford sd's
1997 F-350 PSD CREW LONG BED, BANKS DOWN PIPE,CUSTOM EXHAUST,BANKS TRANS-COMMAND, EGT,BOOST,TRANS TEMP.FPR SHIM, GUAGES.PIAA DRIVING LIGHTS,MY CUSTOM INTAKE,DIY INJECTORS
My house is guarded by SMITH&WESSON 4 nights a week. You Guess Which Ones!
I DONT DIAL 911
burmad69 is offline
