IDM failure....HELP - Ford Powerstroke Diesel Forum
post #1 of 34 Old 11-14-2008, 01:53 PM Thread Starter
Shaking the Bush Boss
CHUCK's Avatar
IDM failure....HELP
Still having trouble with my truck. I replaced the oil temp sensor, and no change.
New code sample.....p???? IDM failure.
The truck still starts and idles,it will even move about 50ft before the engine loses any power.....I thought if the IDM went bad, the truck wouldnt start????
Chuck
CHUCK is offline
post #2 of 34 Old 11-14-2008, 02:19 PM
Is your oil level were it should be?
Diesel Monkey is offline
post #3 of 34 Old 11-14-2008, 02:20 PM Thread Starter
CHUCK's Avatar
come on guys...some out there knows the answer...
Chuck
CHUCK is offline
post #4 of 34 Old 11-14-2008, 02:20 PM Thread Starter
CHUCK's Avatar
engine or hpop? both should be good
Chuck
CHUCK is offline
post #5 of 34 Old 11-14-2008, 02:31 PM
Engine oil fills HPOP reservoir. I only ask because the small oil leak on my truck got a little bigger and in three days a gallon and a half was missing. I could go about 65 feet and air would get into the HPOP, and it would quit. It was just a small leak on the HPOP oring and a small seep out of the turbo pedestal that spilled the gallon and a half. I have a pressure gauge that I installed onto the oil line between the HPOP and head, reved the motor for 10 seconds and pressure bliped below 500psi and it quit. Fixed the oil leaks, added oil and has not had a problem. Weird.
You should also check the engine electrical harness for shorts, it may be seeing a condition that causes the PCM to "reboot".
I am assuming that the filters and fuel pressure is good also on your truck.
post #6 of 34 Old 11-14-2008, 02:36 PM Thread Starter
CHUCK's Avatar
I'll check. I lose alittle oil between every oil change. Lost abut a teaspoon of oil out of the hpop, when I changed the eot sendor
Chuck
CHUCK is offline
post #7 of 34 Old 11-14-2008, 03:17 PM Thread Starter
CHUCK's Avatar
Someone, anyone.....
Chuck
CHUCK is offline
post #8 of 34 Old 11-14-2008, 04:46 PM Thread Starter
CHUCK's Avatar
bump to the top again
Chuck
CHUCK is offline
post #9 of 34 Old 11-14-2008, 04:53 PM
sldghamr's Avatar
a failing IDM will result in the symptoms you are seeing. mine went out a few months back. it is a Ford only item, the IH version will not work cuz of programming differences, also it is $1100 or so at the dealer. i suggest going to a wrecking yard and find a used one to test the one you have. the only advantage of buying a new one from Ford is that you get all of the updates for your year.
if you see a light at the end of the tunnel, it's probably just a photon torpedo
sldghamr is offline
post #10 of 34 Old 11-14-2008, 04:56 PM
97powerstroker's Avatar
does it s thing ontart quicky and consistently? then is diese shortly after,sounds like a cps to me,im almost 100% sure you've tried that so......give some more details,like did it slowly get worse or was it a sudden thing one day.
96 F250 460-auto-ext.cab-long box-4.10-152k-10mpg all day running or not.....
97powerstroker is offline
