oil temp sensor
14K views 9 replies 4 participants last post by  DneprDave
has anyone replaced one? where is it located? I think mine is faulty, i have no high idle at warm up which things point to a bad oil temp sensor
Subscribing
I can count on 1 hand the amount of times the high idle came on and it was for maybe 15 seconds. Even at 20 below if its plugged in it does not come on.
engine light was on, so i went and got the scanner. I havent ever noticed a high idle when its cold out. The Exhaust Back Pressure Sensor...operates the EBPValve in the turbo, will close, causing the engine to work harder, building heat faster.
#10 · (Edited)
The electrical connection is broken off my Engine Oil Temperature sensor, all it seems to do is tell the glow plugs to stay on, as if the engine were cold, even when it is warmed up. Idle is fine, runs good. Check engine light is on, but no code is set.
Does anyone have a part number for the EOT sensor?
Update:
Got one from the local Ford dealer, p/n: DY-961 F5AZ-12A648-AB
