dropped off truck at the mechanics
well i got tired of tryin to fix the issue im havin with it.
we'll see in a few days when the mechanic gets to it. also, i happen to see some black smoke while on the highway. and its all stock.(at the moment)the mechanic right off said it might be the front cover after i told him what been done to it. so im hopping its the cover. Last edited by Jarrod B; 11-12-2008 at 03:15 PM. |
ok
i called the mechanic today to checkup on the truck. they found that the heater core and an oring on the water pump was leaking. so they temporally bypassed the heater core and replaced the oring in the pump. then they drained the oil and hooked up the cooling system to the pressure machine at the shop and left it with it on to see if there was any coolant in the tray in the morning. no leaks detected. so then they talked with the other mechanics to determine the next thing to do. they put a uv dye in the oil system to check for contamination in the coolant after some driving. so i picked it up today and drove it home. next week ill drive it about a 100 mi then drive it back to the shop for them to find the leak with the dye. |
dropped it off today. coolant still goes down and now there is milky white in the degas bottle
degas bottle?
that sucks! sounds like a really small internal hole but then again, i dunno wat im talking abouthave you added anti-cavitation to the coolant ever? |
ah no
done head gaskets oil cooler injector orings water pump rebuilt radiator the tech thinks front cover it was rebuild at 260k theres 326 on it right now |
again, i have no idea what im talking about.
front cover? as in timing cover? (im engine illiterate) |
ya front timing cover
whats the problem???
Keep us posted.
the problem is that it mixes oil and coolant
![]() will do |
