Fluids - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-11-2008, 03:47 PM Thread Starter
Fluids
Ok, time to change the fluids in my truck. I have the oil and Anti freeze down, but i want to change the front/rear diffs, tcase, and trans fluids. Napa isnt showing what i should use for fluid, so im assuming its dealer only stuff?
Slow91 is offline
post #2 of 6 Old 11-11-2008, 03:56 PM
Raul@Stealth Automotive's Avatar
you can use motorcraft or Amsoil....
your Tcase uses regular ATF... same thing for your trans.. we use Sevear gear Amsoil on the diffs....
Raul@Stealth Automotive is offline
post #3 of 6 Old 11-11-2008, 05:06 PM
Super Kaz's Avatar
Send a message via AIM to Super Kaz
I got this off of alldata at work:
*Front differential Oil Capacity 5.9pt
-Front differential Fluid Type SAE 90 Premium Axle Lubricant C2AZ-19580-F
-Specification ESW-M2C105-A
*Rear Differential Oil Capacity
-Dana 80 (Conventional/ Truetrac diff) 8.5 pt
-Dana 80 (Trac Loc) 8.0 pt
-Dana S135 24.5 pt
-Ford 10.50-Inch Ring Gear 7.0 pt
-Friction Modifer 8.0 oz
Rear Differential Fluid Type
*Ford 10.50 Inch Ring Gear
-SAE 75W140 High Proformance Rear Axle Lubricant
-Additive Friction Modifier C8AZ-19B546-A
*Dana 80 Axle
-SAE 75W90 Thermally Stable Multi-Purpose Gear Lubricant
Transfer Case Fluid
-Type Mercon ATF
-Capacity 2.0 qt
2000 F-350 Ext Cab Dually
"TOW TRUCK"
Mods: AIH Delete, DIY Tymar Intake, Modded IDM, Zoodad, FBD 5" Straight Pipe Exhaust, ITP Overboost Annihilator, 60 HP Mystery Chip
15.4 @ 87 mph On The Evo
...254k, And Still Going
Super Kaz is offline
post #4 of 6 Old 11-11-2008, 05:16 PM
Super Kaz's Avatar
These are for a 99 and up Superduty. Sorry
"TOW TRUCK"
post #5 of 6 Old 11-11-2008, 09:15 PM
TDIPowerstroke's Avatar
does anyone know the type and quanity for a 96 F350 4X4, E4OD,
I've been thinking about switching to synthetics if anyone has any input.
New Girl-2016 F250 Lariat 4X4 CC
96 F350 4X4 SRW,CC (gone)
TDIPowerstroke is offline
post #6 of 6 Old 03-05-2009, 06:53 PM
dusted4eva's Avatar
Send a message via MSN to dusted4eva
Do you guys use the Ford Additive Friction Modifier C8AZ-19B546-A with the Amsoil Severe Gear.
dusted4eva is offline
