Thinking
Becasue I dont have alot of money because of the holidays coming i was wondering if i can delete my Cat and muffler with a stiaght peice of 3inch with adapters letting it just slide on ill cut the muffler and cat off
its a 96 f350 psd 4x4 |
The stock exhaust is 3.5" so you would need some 3.5" pipe then that would work fine
okay thanks will i be able at least hear the turbo threw the exhust alittle i no its stock dp but still no cat and muffler is no restiction
yeah you will definitely hear the turbo more, the stock cat and muffler are very restrictive.
sweet in the spring im doing 4inch dp with straight pipes to 5 inch tip all ss
i dont like stock exhust so ill find out if i need it for emmsions now then spend like 500 on a system when ill just weld on my cat |
does anyone know where i can get like maybe 3 or 4 feet of 3.5" of pipe with adaptors so i can slide it on
The biggest youll be able to get is a 3" downpipe as far as the pipe I would go to an exhuast shop
And you dont need a cat...just muffler
If you have a 96 your not going to do a 4 inch down pipe unless you have one made and do some major work on your floorboard, from what I hear.
i was ordering the mbrp 4 inch turbo back does that mean 3 inch down to 4 inch pipe i really dont know
MBRP Inc Performance Exhaust - Snowmobile, Diesel, Muscle Car, Exotic, Motorcycle and Sport Truck Exhaust Systems. |
