Poor mileage - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-02-2014, 02:20 PM Thread Starter
Poor mileage
I know.. I drive a 1 ton, I shouldn't expect mileage, and I don't. Buy I expect more than 10mpg, come to realize after a drive, my passenger rear brake drum is excessively warm compared to the other a side, in guessing I have something hanging up? Any ideas what it could be ?
austinlibke is offline
post #2 of 8 Old 03-02-2014, 03:45 PM
My 1 ton gets 17mpg, and my rear brakes drag a little.
There is definitely something wrong. Do you use your parking brake? You may have a cable sticking. A bad rubber brake line will act like a check valve, so you may have one of those too.
1997 F-350 7.3 5 Speed 4x4, 320k Miles
benspilk09 is offline
post #3 of 8 Old 03-02-2014, 04:22 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Average runs 15-17, so you are low.
You could have a boost leak, a pre turbo exhaust leak, brakes, and other things. A brake alone shouldn't drop you that much. I think it's a combination of things. I'm down 1-2MPG right now, and I know that I need an alignment, so I'm sure that's part of it.
Fixing a sticking caliper on the rear gained me 1MPG.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 8 Old 03-03-2014, 03:40 AM Thread Starter
Im predicting I need an alignment and a wheel bearing up front, how do you test for exhaust leaks or mostly, boost leaks
post #5 of 8 Old 03-03-2014, 06:48 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
It's winter, winter fuel drops mileage as well, look for soot around the up pipes, manifolds, pre turbo, inspect the boots from the turbo to the heads as well, unstick your brakes too
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #6 of 8 Old 03-03-2014, 07:43 AM Thread Starter
I have heard you can't get mileage on winter blend.. Not to mention the 20+ minutes of warm up time before going anywhere
post #7 of 8 Old 03-03-2014, 10:17 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
10 is still low however, but on the winter fuel you still can't expect 20, maybe 15-17 tho
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #8 of 8 Old 03-03-2014, 11:47 AM Thread Starter
Agreed, I wasn't expecting anything stupendous especially in the winter.. DVD I knew ten had to be low, I don't drive very far, so I never thought much of it, but recently went on an hour drive one way and she did not do any better, so back to the parts store I go!
