Part number help - Ford Powerstroke Diesel Forum
Old 11-10-2008, 06:53 AM
Thats Mr. Oil Leak.....
Exclamation Part number help
Does anyone have part numbers for the following?
valve cover gasket
uvc harness's
Harness connector ( the connector that goes off of the main wire harness that plugs into the front connector on the driver side valve cover gasket)
This is for my buddies 97 stroke. The harness has shorted out and we are working on replacing these items and hoping it hasn't ruined the injectors...
Old 11-10-2008, 08:43 AM
cj41foleyisathief
Call Ben at powerstrokeshops.com
Old 11-10-2008, 04:09 PM
These are what your looking for John:
Valve Cover Harness Repair Kits (contains 4 hard shells w/seals, w/o terminals)
(Ford) F7TZ-14489-BA (94-96)
(Ford) F7TZ-14489-AA (97)
(International) 1830829C91 removal tool and Shells w/o pins
(International) 1661875C1 Pins
(International) 2501055C1 Pins with 6" wire
Valve cover harness replacement terminals:
Industry P/N 103935; Winzer Distributing (1-800-527-4126) selection number D52
Valve Cover Gasket (94-97)
(Ford) F4TZ-6584-A
(International) 1818350C2
Valve Cover Harness, under valve cover
(Ford) F4TZ-9D930-K (94-97)
(International) 1815923C92 (94-97)
Old 11-10-2008, 05:16 PM
cj41foleyisathief
Call Ben. They have the VCG for 52.00 ea. UVCH for 31.00 ea and the VCH [the ones you don't have make up and with a 8'' pigtail] for 7.00 ea. One call gets it all........................
Old 11-10-2008, 05:32 PM
I tried calling ben but getting ahold of powerstrokeshop.com on the phone is hard as hell...
My buddy already went out and bought the vcg and uvc harnesses..
thanks for the other numbers Rick!
Old 11-10-2008, 06:42 PM
just bought the valve cover repair kit from rockauto.com
$59 per side gets you the gasket, the 2 uvc harness' and the 2 pigtails that plug into the vc gasket.
I emailed powerstrokeshop as i didn't find these parts in the catalogue and they never responded.
Old 11-11-2008, 06:39 AM
Man Wish I would have known about Rockauto before. Thanks for the info 95!
Old 11-11-2008, 08:04 AM
No prob i found a thread on here where someone had recommended rockauto for the VC kit. I called ford and garage price was $280 a side. $59 vs $280
Old 11-11-2008, 09:56 AM
yeah all the ford houses I talked to couldn't find the pig tail and wanted to sell me a 600 dollar harness...
