smoked cab lights?? - Ford Powerstroke Diesel Forum
Old 11-09-2008, 11:29 PM
Question smoked cab lights??
Wanted to know if anybody has or knows if any company makes smoked cab lights for the obs? if not, will the ones from recon for the 99 and up lights fit on the obs?
Old 11-10-2008, 07:32 AM
Rob Rob is offline
you can put the newer style on any truck.. i dont know of anyone else that makes the OBS lights in a smoke option.
Old 11-10-2008, 08:04 AM
or you could have your lights smoked
Old 11-10-2008, 08:21 AM
just like said above.. you can put the newer lights or smoke yours out...
the ones from recon (replacement lenses) will not fit your stockers.. but if you went with the full LED converstion it comes with a new base and the wire harness.... only thing is that if you have stock cab lights the wholes will not match.... youll have to drill new ones for the Recon and patch up some from your OEM ones...
-Raul
Old 11-10-2008, 10:41 AM
No one makes ANY aftermarket STOCK style lights other than AMBER for the OBS trucks....
Either...
1)Get stock Amber ones and smoke them
2)Get 99+ stock Amber ones and then get the Smoked housings...
But if you currently have lights, they will have to be RE DRILLED.
