Starts smooth, then instantly to 4 cyl's, then stalls. UVCH fine. ??? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-01-2014, 12:35 PM Thread Starter
95 E(yes)350. It's been down at least 1 gp the last 4 years, but it's such a PITA to get the covers off in the van that I figured I'd wait til I needed to get in there for something else. As such, it starts rough as heck if it's in the teens or colder unless plugged in, then smooths out.
Last night I forgot to plug it in, managed to get it plugged in for about an hour this morning in 2F temps before I had to leave, which isn't really enough. Started right up, though, blowing lots of white smoke and chugging per usual until it's warm enough to run on all 8. When it sounded like it was on all 8, I went to back out the driveway and she stalled after about 15 feet. CEL came on. Now the only way to get it to start is to hold the gas all the way down: For the first couple revolutions it's smooth and nice, then it sounds like it's on 4 cylinders for a few chugs, then stalls.
I don't have AE, but I do have a locked chip scanner. Only code registered was P0478, which is for the EBPV--I have no idea if this code could be old, as I haven't had reason to scan this van in ages. I cleared the code and it hasn't come back through the day of working on it.
What I've checked:
Pulled the IDM harness off and checked continuity for the feeds and return on all injectors. All are 2.9 except two are 3.1--totally within spec.
Tried starting w/o the ICP sensor and without the EBPV sensor, with no difference besides throwing the respective codes.
Truck has been plugged in all day and it's in the high 20's so it should have no issues starting. It starts IMMEDIATELY, actually, but almost instantly drops to a horrible chug then stalls.
Backstory: I replaced the drivers' VCG and UVCH's about 4 years ago, plus whatever GP were bad on that side. It's a chore on a van. The passenger side showed 1 dead GP then, and the front passenger VCG clip was RTV'd on by the previous owner... but since I can ohm it out from the IDM harness, I've not messed with it. The right rear two GP's are dead for sure as of today. There's a stacor relay on it that is functioning fine.
Also, though I think it's unrelated, the oil cooler seals shat the bed a few weeks ago and I pulled the whole thing apart and resealed it. No leaks and it's been running fine since.
My gut says it's symptoms of a UVCH issue, and I'm thinking to just open it up and see, but with healthy readings it seems like a fool's errand. I have no way to buzz the cylinders.
Any ideas? I need this thing up and running... and had planned to sell the van off at the end of this spring, so I'm not really excited about sinking a fortune into AE.
Thanks.
Luke in NY
edit: Follow your gut I guess. Spent the rest of the afternoon working the valve cover off and the connector that I WAS able to check is fried inside. Mods feel free to delete--I don't see how I can do it?
ldeikis is offline
post #2 of 2 Old 03-01-2014, 05:24 PM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
You may want to remove the IDM and check for possible water intrusion (the vans had more issues with that particular problem). Cheers!
Patrick Feeley is offline
