want advice on replacement valve cover gaskets and harness - Ford Powerstroke Diesel Forum
post #1 of 17 Old 02-28-2014, 11:00 PM Thread Starter
kctyphoon's Avatar
not urgent, but have a long list of stuff to do with my truck in spring. need advice on buying replacement valve cover gaskets and wiring harnesses. does everyone use/suggest motorcraft or are people having good luck with any of these ebay ones? all suggestions welcome, part number and prices a big help too if you remember them.
kctyphoon is offline
post #2 of 17 Old 03-01-2014, 03:47 AM
OEM for sure, aftermarkets seem to be a crap shoot.
okietom is offline
post #3 of 17 Old 03-01-2014, 10:37 PM
theforeman57's Avatar
Quoted: 4 Post(s)
Motorcraft VC F4TZ-6584A x2
Motorcraft UVCH F4TZ-9D930-K x4
Motorcraft GP F4TZ-12A342-BA x8
You will also need the engine side pigtail, But I don't have that part number in my bible.
Tousley Ford ( They go by a different name now, That is what they used to be called) has better prices.
Yes, IH or Motor is the only way to go. Might as well do gpr as well, search for western plow relay, or I can proved the oe part number.
Axel --> 16yo
96 CCLB srw. built E4OD, Diy E-fuel, Autometer gauges
4:10 lsd, Toyo M55 on stock steelies
Future plans include diy Traction bars, and zf5 swap.
theforeman57 is offline
post #4 of 17 Old 03-02-2014, 07:04 AM
vandy's Avatar
I bought 2 sets from advance auto and have had no issues yet. But the day is young. Came with 2 engine side pigtails and everything under the valve cover
vandy is offline
post #5 of 17 Old 03-02-2014, 07:13 AM
I got a Dorman set from oreilly's because I needed the truck running that day.
They work, but I don't like their clips. The need to be bent, or else they don't stay put on the fuel injector.
The factory harness doesn't plug into the valve cover very easy either.
1997 F-350 7.3 5 Speed 4x4, 320k Miles
benspilk09 is offline
post #6 of 17 Old 03-02-2014, 08:42 AM
Quoted: 4 Post(s)
I have one on My truck as well, Just so I could move it around the yard, but there have been stories where the pins are shorted, or crossed, in the gasket. another big thing is that the wire in the dorman is usually aluminum instead of copper.
Axel --> 16yo
post #7 of 17 Old 03-02-2014, 01:15 PM
the baconator
terryknight's Avatar
Quoted: 150 Post(s)
aluminum wiring is only good for 2 years 20
k then you'll be back under there doing it again. use ford/IH the first time
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #8 of 17 Old 03-02-2014, 03:47 PM
I agree, the OEM's aren't THAT much more than the dorman set.
I can have my passenger valve cover off in 10 minutes though, so doing it again won't kill me.
post #9 of 17 Old 03-07-2014, 04:55 PM Thread Starter
kctyphoon's Avatar
I'm gonna try to force myself to fix everything that needs to be fixed on my truck this spring.. List is getting long.....
post #10 of 17 Old 03-09-2014, 09:19 AM
speedracer7c's Avatar
i have the dorman ones on my truck worked fine, as others have said it was hard to plug in the factory harnesses but other than that no issues
97 F350 Reg cab XLT 7.3, ZF5 Swap, Diamond eye 4" turbo back,Riffraff 6637, Deleted pedestal and outlet, riffraff billet wheel, Baby Swamps, Ts 6 pos with swamps tunes Glow shift triple gauge pod
340k miles and kicking!
2016 F-250 Supercab 6.7
speedracer7c is offline
