Running on 7 Cylinders When Warm - Ford Powerstroke Diesel Forum
post #1 of 50 Old 02-28-2014, 08:42 PM Thread Starter
97 Powerstroke, starts and runs fine when cold but develops a miss/lope when up to temperature. It is definitely not running on all cylinders when you stand on it, it is down on power and runs rough. It doesn't seem to build any boost either. It doesn't have any blow-by, the turbo bearings are nice and tight, and the fins looked fine when I checked for turbo issues.
Oil is new 15-40W Rotella with a Motorcraft filter. New fuel filter. Where do I start looking for this problem? I'm about to pull the valve covers and inspect the wiring, is there anything I should do first though?
I unplugged the two connectors on the drivers side and checked the injector pins, all checked fine with the multimeter. I'll do the same with the drivers side tomorrow when its not dark out. I'm suspecting/hoping it is just injector o-rings. It does have a slow oil leak that seems to be coming from the plug in the rear drivers side oil rail in the head, though its slow enough I don't see it causing the problem.
1997 F-350 7.3 5 Speed 4x4, 320k Miles
benspilk09 is offline
post #2 of 50 Old 02-28-2014, 09:00 PM Thread Starter
Forgot to mention I have no CEL, and my cheap scanner doesn't pick up anything. I know the CEL bulb works, because it was flashing at me a while back when I was having trouble with my idle validation switch.
It sounds exactly like this guy's excursion when warmed up:
post #3 of 50 Old 03-01-2014, 06:30 AM
rolsmojave3's Avatar
You need a good scanner and do a Cylinder Contribution test. Although you can remove the valve covers and unplug one injector at a time and see which one has no effect on engine performance. It would also help to see what your ICP levels are at. A good scanner would also be able to check this however you can rig up a gauge.
Use the search to find the ICP gauge setup
Where are you located? Many guys on here are willing to help if you're close.
1997 Ford F-350 4x4 SRW regular cab manual trans.
-4.10s, 315/75r16...getting a frame off restoration. Go fast stuff
1996 Ford F-350 4x4 SRW CCLB manual trans. CALI spec
-ATS intercooler, WW2 w/ 1.0 housing/EPBV delete, Comp 910s, SD Efuel, 3.55s, 315/75r16
2002 Ranger FX4 with manual transfer case and Alcoa's
rolsmojave3 is offline
post #4 of 50 Old 03-01-2014, 06:40 AM Thread Starter
I'm outside Little Rock, Arkansas.
What scanner setup do you recommend? I might as well buy one, since I plan on having the truck (or a different 7.3) for a long time.
I am leaning towards a scangauge since they seem to monitor a ton of useful stuff, I would like the MPG readout as well. I have read they will do a buzz test and pull codes on our trucks, is this true?
post #5 of 50 Old 03-01-2014, 08:53 AM
I'm not sure on the Scangauge. I know guys used to like the Snap On "red brick" scanner as they're now cheap and do the tests on these trucks. I have a Matco Proscan and it works great.
Before going to far I would inspect all UVCH's for burnt connections. On a few I've done I've always pulled the oil cap and taken a smell, you can usually smell the burnt connection before pulling the valve covers. If they are OK check the engine wiring harness to the plug on the driverside inner fender. I've seen pins pull out of the connector there. If that's OK, get the scanner and buzz test the injectors. If they're coming back OK you get to dig a little farther.
Once you determine what cylinder(s) is giving you an issue you can take proper action with a compression test, swap injector between cylinders to see if the issue follows the injector etc etc.
These engines aren't that hard to work on and usually require just a little patience to work under the hood. There is many how to's on here that cover the basics.
post #6 of 50 Old 03-01-2014, 09:03 AM Thread Starter
Ok I got around to pulling the intake and testing all the injector circuits. All tested right at 3.5 ohms on the drivers side, and the front three tested 3.5 on the passenger side.
The rear cylinder on the passenger side is showing 4.5-5 ohms every time I test it, so I hope I found the problem. Off to pull the valve cover, looks fairily easy.
post #7 of 50 Old 03-01-2014, 09:05 AM
Good, glad you found it easily.
post #8 of 50 Old 03-01-2014, 10:30 AM Thread Starter
Got the valve cover off, there isn't really any obvious damage to the harness.
It has a LITTLE bit of melting on the plug to the rear glow plug, I guess I'll replace it anyway. It runs fine with the cover off, unplug that injector and it runs like it does warm.
post #9 of 50 Old 03-01-2014, 12:16 PM Thread Starter
Ok, replaced the gasket and wiring harness on that side. Took it for a test drive, did the same thing. It ran great until it got warm, then back to running on 7 cylinders.
The injector resistance was right when I tested it with the new harness, 3.5 ohms at every injector.
Its the number 7 cylinder that is giving fits, 90% sure. Can I just swap it with any injector?
post #10 of 50 Old 03-01-2014, 12:31 PM
Did you replace the pigtail on the valley side? You can switch the injector with any other one, however I would get a couple of new O ring sets for the switch. If you don't want to switch them, do a compression test after its warm and see what you get. I was in ORielly auto parts the other day and they rent the diesel compression tester.
The Following User Says Thank You to rolsmojave3 For This Useful Post:
jlee9541 (03-05-2014)
