Weird clacking noise coming from engine/tranny - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-28-2014, 01:03 PM Thread Starter
connorr93 is offline
post #2 of 4 Old 02-28-2014, 02:54 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 43 Post(s)
Manual or auto? Manual then its time for a single mass clutch, auto looking at worn front bearing, broken flexplate teeth, TC internal damage. For either: loose motor to trans bolts causing misalignment, loose starter, motor mount, trans mount.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 4 Old 02-28-2014, 07:42 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Or cracked flex plate (around the hub). Cheers!
Patrick Feeley is offline
post #4 of 4 Old 03-04-2014, 09:17 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 43 Post(s)
Open a photobucket account take a video, upload it, and post please. Meanwhile remove the intake and look around the turbo inlet. Grab the impeller (engine off) and try and move it around (should not be able to push/pull in any direction, it should only rotate). I'm wondering if your turbo bearings are shot and allowing the impeller to strike the housing.
Next, pull both valve covers and check the push rods and rockers. They should be tight, any real loose parts generally means bent push rod. Not common but definitely a weak spot in these engines.
Matt
'97
-Stage II trans.
BigFuel is offline
