trans swap question - Ford Powerstroke Diesel Forum
post #1 of 9 Old 02-27-2014, 09:59 PM Thread Starter
jjones96's Avatar
trans swap question
Here is a question for u guys just swapped my e4od out for a zf 5.
I just sent my chip off to get reburnt so that it won't throw the automatic codes.
So is it ok to drive the truck while its in limp mode.
I start my truck the idle jumps around until the check engine light comes on then it idles Smooth.
Is it ok to drive? Until i get my chip back? Or will it hurt the engine?
The STROKE
1996 F-250 Powerstroke
7.3 DI T444E.
TS 6 Postion chip
Gloshift max tow gauges
3 inch dp to 5 inch exhaust
diy intake 6637
The Wheeler
1987 Jeep Cherokee
4.0 inline 6
3 inch rustys lift
Cut fenders
33x12.50 r15
Redneck weight reduction
The work truck
2012 Ford F-350 DRW 6.7 Powerstroke
C&M Flatbed
100 gallon slip tank
ProTech side boxes
The Bike
2006 CRF 450R
some go fast parts
Endless other sh*t
jjones96 is offline
post #2 of 9 Old 02-28-2014, 03:54 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
May wanna see what code it's throwing, a trans code usually only sets off the of flash, but I have a friend who drives his with the 5 Spd swap and zero ill effect other then fueling characteristics, and the od flash (still has tunes for an auto on his chip from swamps)
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 9 Old 02-28-2014, 06:47 AM
speedracer7c's Avatar
Did you change the harness as well? I left the range sensor in the frame and have no CEL or running issues at all.
97 F350 Reg cab XLT 7.3, ZF5 Swap, Diamond eye 4" turbo back,Riffraff 6637, Deleted pedestal and outlet, riffraff billet wheel, Baby Swamps, Ts 6 pos with swamps tunes Glow shift triple gauge pod
340k miles and kicking!
2016 F-250 Supercab 6.7
speedracer7c is offline
post #4 of 9 Old 02-28-2014, 08:49 AM Thread Starter
jjones96's Avatar
Still have the auto harness and I left the prndl switch plugged in. Its throwing p0708 p0713 I know for sure I gotta check to see what the others are. The 708 is tranny temp sensor and 713 is range sensor.
The STROKE
7.3 DI T444E.
TS 6 Postion chip
diy intake 6637
The Wheeler
1987 Jeep Cherokee
4.0 inline 6
3 inch rustys lift
Cut fenders
33x12.50 r15
The work truck
C&M Flatbed
ProTech side boxes
The Bike
2006 CRF 450R
some go fast parts
Endless other sh*t
jjones96 is offline
post #5 of 9 Old 02-28-2014, 10:33 AM Thread Starter
jjones96's Avatar
I figured out what's throwing it into limp mode p1212 ICP voltage not at expected
The STROKE
7.3 DI T444E.
TS 6 Postion chip
diy intake 6637
The Wheeler
1987 Jeep Cherokee
4.0 inline 6
3 inch rustys lift
Cut fenders
33x12.50 r15
The work truck
C&M Flatbed
ProTech side boxes
The Bike
2006 CRF 450R
some go fast parts
Endless other sh*t
jjones96 is offline
post #6 of 9 Old 02-28-2014, 10:37 AM
Quoted: 50 Post(s)
What position is the trans range switch in?
madpogue is offline
post #7 of 9 Old 02-28-2014, 02:35 PM
i left mine in park when i swapped
post #8 of 9 Old 02-28-2014, 07:08 PM Thread Starter
jjones96's Avatar
Its in park
The STROKE
7.3 DI T444E.
TS 6 Postion chip
diy intake 6637
The Wheeler
1987 Jeep Cherokee
4.0 inline 6
3 inch rustys lift
Cut fenders
33x12.50 r15
The work truck
C&M Flatbed
ProTech side boxes
The Bike
2006 CRF 450R
some go fast parts
Endless other sh*t
jjones96 is offline
post #9 of 9 Old 03-01-2014, 06:45 AM
Quoted: 50 Post(s)
Try sliding the switch to where it would be in Neutral. Jumping idle on an automatic often means that switch isn't properly detecting Park.
madpogue is offline
