4x2 to 4x4 questions - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-27-2014, 12:38 PM Thread Starter
I am tired of my 96 PSD 2wd dually getting stuck in the snow. I have a line on an 89 idi 4x4 dumptruck. They are both 5 speeds. From what I have found the 89 tranny will bolt to my psd. Is there any thing that would prevent this swap from being possible? I am new to Fords and want to make sure before I pick up the dump truck. Only hang up I can think of is the speedo. 89 would be mechanical and 96 is electric. Any help would be appreciated. I am not worried about the suspension swap over. I could always cut the frame and graft the front section on from the dump truck....I am no stranger to welding and fabrication.
buggy5872 is offline
post #2 of 4 Old 02-28-2014, 07:53 AM
speedracer7c's Avatar
The trans will swap in without issue. You'll need a clutch from your model year truck.You will also need a pedal assembly out of a 92+ year truck. The speed sensor for your truck is in the rear axle so theres no issue with swapping the trans. You'll need a longer rear driveshaft as the zf is shorter.
97 F350 Reg cab XLT 7.3, ZF5 Swap, Diamond eye 4" turbo back,Riffraff 6637, Deleted pedestal and outlet, riffraff billet wheel, Baby Swamps, Ts 6 pos with swamps tunes Glow shift triple gauge pod
340k miles and kicking!
2016 F-250 Supercab 6.7
speedracer7c is offline
post #3 of 4 Old 02-28-2014, 09:02 AM Thread Starter
Thanks for the info. Mine is already a 5 speed so I should not have to hunt any extra parts down
post #4 of 4 Old 02-28-2014, 12:33 PM
the baconator
terryknight's Avatar
Quoted: 141 Post(s)
4x4 front ends are boxed 4x2s are not. the front of the frames for 87-91 are different than the 92-97
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
