Tranny ideas - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-27-2014, 05:32 AM Thread Starter
sandrock1's Avatar
Tranny ideas
I need to get a new front seal for my e4od. I heard viton makes a good one. Any other ideas for the seal? And I also want to get a huge cooler for the transmission along with a temp gauge. I don't want nothing fancy I just want it to be inexpensive. I can't go on a long ride without the transmission getting red hot so I'm trying to fix this problem. Any other things I should try before I want to switch it for a manual? Thanks.
sandrock1 is offline
post #2 of 6 Old 02-27-2014, 07:28 PM
Johnny Law Brown
jc82chevyman's Avatar
If your trans is heating up just from normal driving than there is an issue that needs to be resolved besides replacing the front seal as far as a cooler is concerned scouring the junk yards for a 6.0 cooler do a search for it I believe there is a DIY thread on it.
2002 F-250 IH 444E
AFE Stage II
GTP38R
4" TB exhaust
35" BF Goodies
1995 F-250 IH 444E
jc82chevyman is offline
post #3 of 6 Old 03-09-2014, 11:48 AM Thread Starter
sandrock1's Avatar
Well I put a new seal in. I think it is slipping though. It got really hot real fast. If a lock the torque converter with a switch, it seams to catch the slightest bit but will not come close to stalling the truck when I stop. It's like you let the clutch out just till it barely starts to pull but you can still be stopped. Any thoughts?
post #4 of 6 Old 03-10-2014, 06:23 PM
leojr's Avatar
Quoted: 4 Post(s)
If you lock the converter with a switch you installed it doesn't stall the engine?
Denton, TX
I envy those that know exactly which modification to make and in the most logical of sequences. But not enough to trade for my meanderings and misfires.
1996 F250 crew cab/short bed, 4x4, auto PSD, 6637 air filter, interior grab handles, stainless window vents, remote door locks work with engine running mod.
leojr is offline
post #5 of 6 Old 03-11-2014, 07:42 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 57 Post(s)
Torque converter is burned out. The lock-up clutch is gone and this is where your heat is coming from and maybe even the melted front seal. Time for a new TC.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #6 of 6 Old 03-13-2014, 05:18 AM Thread Starter
sandrock1's Avatar
Ok thanks. I will maybe try just a different torque converter and see how it acts. I will keep this updated as I try it. Is there anything I should keep in mind while swapping a torque converter. I'm planning on getting a low mileage one from a junk yard.
