Couple of q's for ya - Ford Powerstroke Diesel Forum
post #1 of 5 Old 02-26-2014, 03:38 PM Thread Starter
Quoted: 3 Post(s)
Hello all, I currently own a 2000 Super Duty but just came across a great deal on a lower mileage 97 obs that has a couple of problems and Im wondering if I should pick it up? My main reason for considering this is because it is a 4 door and I don't have to smog a 97 here in California.
The biggest issue is that it is a California edition which I hear is no good? It has some issues regaurding the PCM which I figure relates to it being a CA edition. It will run just fine and then out of the blue just die. Sometimes you can start it up sometimes not. Is there a way I can convert to an older or newer PCM?
My next round of questions Involves performance. How much power can I make without an intercooler? Meaning when is it a necessity? Same question goes for and e-fuel conversion? Do I need to do that? I would plan on a d66, baby swamps or something similar, valve body and possibly a TQ, and tunes,gauges,intake.
One last thing, I will be going off to college in the fall and the climate there compared to the valley in California will be significantly different in regards to temperaturs. It will be way colder where im going and which truck do you think would handle it better?
Sorry for the long post, thanks in advance.
Justin
2000 PSD, 4in Exhaust, 6637 Intake, Zoodad, TS Canned Tunes, JWVB, Billet Wheel, FRx
ilovemy7.3 is offline
post #2 of 5 Old 02-26-2014, 06:43 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
You won't have any issues, both trucks have split shot injectors, swapping to an older or newer PCM requires a re pin of the harness, both obviously require glow plugs and a relay to start in colder climates
The issue the obs seems to have is a CPS, mine did that exact same thing too when I bought it, I've had a Cali model it was the best truck I ever had, e fuel and an ic are not necessary but very nice, e fuel will keep the pressure, and the ic will keep the egt's down longer, obviously all trucks will climb in egt's but the ic prolongs the cooler temps,
The obs is significantly lighter and typically attains better fuel economy, interior is not nearly as lavish, but can be made so, I'd rock the obs if I were you
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 5 Old 02-26-2014, 06:56 PM Thread Starter
Quoted: 3 Post(s)
Thanks for the reply. How hard is the repin? I know there is something wrong with the PCM because they keep going out. I have personally changed the cps, so i don't think that is it. Ill do it again since it was awhile ago. I know the lady who is selling it so there is no hurry in getting it, she said if i want it it's mine!
post #4 of 5 Old 02-26-2014, 07:16 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
The re pin is easy, but in an awkward spot so difficult Kause of that, I've personally never had an issue with the Cali PCM, heard of them going but never personally had the problem, where did you get the CPs from as for that being the problem
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 5 Old 02-26-2014, 07:34 PM Thread Starter
Quoted: 3 Post(s)
what exactly have you heard about the Cali PCM's, do you know what causes them to go out? I got the CPS from Napa (my dad owns one). What color CPS is the good one again, I cant remeber?
