More Engine Room - Ford Powerstroke Diesel Forum
Old 11-05-2008, 10:19 PM
More Engine Room
So how can I get more engine room behind and above the turbo? can I move lines to get acouple more inches of room behind and above the turbo
In this picture here he has considerably more room than I do same body and turbo?
Old 11-05-2008, 11:23 PM
Old 11-07-2008, 10:42 PM
Old 11-08-2008, 03:32 AM
That looks like Jim Rose's truck. PM DZL_JIM and ask him what he did differently. That was one of his set-ups for twin turbos i think back when...
Old 11-08-2008, 03:48 AM
Ole White
I was thinking the same thing talk with Jim he can point you in the right direction
Old 11-08-2008, 03:23 PM
3" Body Lift!!
Old 11-08-2008, 03:48 PM
Originally Posted by DZL JIM View Post
3" Body Lift!!
thats what i was thinking, but your the pro!
Old 11-08-2008, 11:20 PM
haha thanks fellas
Old 11-09-2008, 03:33 AM
There are many opinions out there about body lifts, but you know what they say about opinions.
The body lift was really easy to install, except for maybe some Northern Ohio Winter Gold dust coated bolts. But it was straight forward. You just have to buy the gasser Kit (they don't offer them for diesels), then cut off the bottom of the fan shroud. I also had to heat and bend the 4x4 shift lever. That's about the trickiest thing to do. To date, it's still a pain to get it in and out of 4x4 as easily as before the lift, but it works.
I wouldn't recommend a body lift for anyone using their truck to haul heavy stuff in the bed. There are not enough poly spacers for every rib, and I wouldn't trust them to be stable with a load in the bed anyway. Looks like they could tip over if stressed. I quit hauling with the truck back when I did the lift, but if I ever need to haul with it, I'd seriously make some better 3" blocks than the ones provided. Like some 3" channel run parrallel on top of the frame rails with channel welded across to the other side, like a complete framework for the bed to sit on.
Otherwise I think the lift was one of the best mods I've done to the truck. Makes for lots of room to work on things, but does make it a pain to pull the motor. That extra 3" to raise a 1100# motor is a bit of a pain, but oh well...
Old 11-09-2008, 08:20 AM
Shade tree mechanic
i agree, when i bought my truck back in 2000 it had a body lift already installed. no problems in the 8+ years i have owned it. i have also heard they are a bad idea if you tow/haul? which is wierd, because i am constantly hooked to a trailer and have had zero problems. and like jim said, it makes for more room to get around stuff in the engine bay. a few of the things that i noticed were easier to do repair/mod wise were taking off the valve covers to get to the glow plugs. the other thing that seemed to be easier to do than other people have stated was my DP, this went in with ease and very little bashing of the firewall. other than that i am able to run 35's without rubbing.
