ABS Light - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-24-2014, 06:21 AM Thread Starter
PhilMac's Avatar
ABS Light
My ABS light is on and also under semi hard braking my rear brakes are locking up. Not sure if its one or both tires that do it but I hear it skid on occassion. Any thoughts. Speedo seems to be working fine.
'97 F-350 7.3 CCLB SRW ZF5 4x4
360,000+ miles
South Bend Stage 1
DP-Tuner - 40T,80T,80E,100P
Boost & EGT Gauge
DE 3" DP & 5" Exhaust
DIY 6637
'77 F-250 Highboy 460ci SCLB C6 4x4
Rebuilt 460ci
Comp Cam, P&P DOVE-C Heads, Holley 770cfm
Flat top pistons. 10.5:1ish compression
PhilMac is offline
post #2 of 3 Old 02-24-2014, 09:06 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 43 Post(s)
With the key off look under the passenger side of the dash (around glove box area) for a black wire with orange stripe. Short it to a ground and get into the drivers seat with a pen and paper. Rotate the key to run (not start) and start counting the ABS light flashes. It can flash between 2 and 16 times for a code. If there are more than one codes there will be a long wait between the flashes. Report back with the counts.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 3 Old 02-25-2014, 06:31 AM
the baconator
terryknight's Avatar
Quoted: 143 Post(s)
do what matt said then fix the problem
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
