where do you look to see if a chip is installed?
New to the forum but love my 97 F250. 153,000 on the clock.
x2, id like to know as well...
If its a chip, you look at the pcm located on these trucks on the firewall, drivers side, you kind of have to get to it by unbolting the fender. There is a 10mm bolt holding in the wiring harness. Then you slide it out and look and see if there is a TW (or other) chip plugged in.
If its a tuner, then you need to plug it into a computer to check |
take off the 3 bolts of the ebrake and under there is the pcm and there is a hole and on mine it had a plastic cover but some dont.
thanks for all your help.
I have a '97 that had a banks something or other sticker on the door, had no idea where to look. Have to look tomorrow..
