What do i need for towing. - Ford Powerstroke Diesel Forum
post #1 of 12 Old 02-22-2014, 09:12 PM Thread Starter
sethc24's Avatar
I need to tow a flatbed trailer and need some guidance in what i need to do to my truck for some light towing.I have never towed anything before. Right now the rear harness(trailer plugin???) is a mess thanks to the previous owner. And there is no brake controller in the cab. Point me in the right direction boys.
1997 F-250 4x4. 5 speed
, 6637,exhaust,dp-tuner,dana 60, 33's
sethc24 is offline
post #2 of 12 Old 02-22-2014, 10:29 PM
vandy's Avatar
Depends on how heavy and what area your in.
For me a min would be a good controler, and some egt/trans gauges.
vandy is offline
post #3 of 12 Old 02-23-2014, 06:16 AM
Vannnce's Avatar
Quoted: 13 Post(s)
if your truck is bone stock and youre not hauling real heavy you can get away with just having youre trailer wiring/controller up to par.
if you plan on hauling a lot, and hauling heavy, id invest in gauges and a tranny cooler upgrade, a good tow tune will wake the truck up
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
post #4 of 12 Old 02-23-2014, 10:03 AM
Having towed a 6000# sailboat for a few years now I can offer this:
Don't let anything overheat! My 10,000# rated Suburban 454 W/ 4:11 rear blew it's exhaust manifold bolts lugging up a steep hill. Now I have a 96 7.3 stock van.
IMHO egt and tranny temp are crucial as well as a good controller. You want a Class 111 equalizer hitch with a 2&1/8 ball. Reese makes a very good anti sway bar that I would also recommend. Stay away from surge brakes on your trailer, unless you don't mind replacing brake cylinders when you forget to put in the back-up pin. If you're going down a steep incline, don't let your engine over rev. keep it slow.
tartansailor is offline
post #5 of 12 Old 02-23-2014, 06:38 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
How light are we talking, a good controller, fix your harness, egt/Trans/boost gauges, larger Trans cooler, make sure you have a good hitch also if it's large good tow mirrors for the nemo's
A little common sense goes a long way, make large turns
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #6 of 12 Old 02-23-2014, 08:18 PM Thread Starter
sethc24's Avatar
Thanks guys. I have a triple pillar gauge setup ( truck is an auto). Tranny temp,pyro,boost. I do have an auxillary transmission cooler to put in. I am not sure if the gvw? is high enough. Its a 20,000 gvvw. What brand of brake controller should i go for? I want one that is going to last. My f5 from dp-tuner has a 60 hp tow file on it.
I will take a close look at the hitch. The load is a volkswagen golf. I have no doubt the truck will pull that easily. I have the 2 post mirrors, not the nemos. Thanks for the input.
sethc24 is offline
post #7 of 12 Old 02-23-2014, 08:27 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
You will be fine, keep an eye on egt and Trans, I like draw tite controllers
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #8 of 12 Old 02-24-2014, 08:20 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 51 Post(s)
I cut off my DrawTite for a Tekonsha Primus IQ. Good for 3 axles, proportional braking forward and reverse, 3 +boost levels, self leveling, brake diagnostics, and anti-roll back. Hit up a wrecking yard to cut off a plug from a newer SD. They'll have a 7-pin and a 4-pin connector in one unit. If the flatbed isn't yours get a picture of the trailer connector so that you have the right one before you show up and assume that the brakes on the trailer are going to be shot. Slow and steady wins the race.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #9 of 12 Old 02-25-2014, 07:26 AM
SoCalPwrStrk's Avatar
Not a big fan of the DrawTite either, had the Activator II and found out the hard way that the emergency flashers activate the trailer brakes. Just ordered the Prodigy P3, hopefully it is worth the $$. If you wiring harness is beyond repair you can order the replacement t-harness but they run about $100 or try your luck at the wrecking yard.
"Big Truck" 1997 F-350 CC DRW 4x2 Cali model
Diamond Eye 3" dp to 5" straight pipe, DIY 6637 intake, Pillar gauges, 6.0 trans cooler, Intercooled, TS 6 pos. chip with TW Tunes, 1.0 Housing, Barder Billet Wheel, EBPV Delete
"Baby Truck" 1999 Ranger EC 5 speed 3.slow
Camburg Long Travel, Billit upper arms, Fox dual rate coilovers and double bypass in front, Deaver race pack w/ fox double bypass in rear, fiberglass fenders, 16x8 American Racing Mohave Wheels
SoCalPwrStrk is offline
post #10 of 12 Old 02-25-2014, 08:00 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 51 Post(s)
Almost got that one but wanted to see it work before spending the money. Now trucks come with built-in controllers and hardly anyone has aftermarket controllers anymore. Settled on the one one step down. Very happy with my Tekonsha Controller.
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
