Rust - Ford Powerstroke Diesel Forum
Old 11-03-2008, 05:44 PM
Rust
Not really a engine question but i have a little fender rot abot 2 inches by one inch under the chrome fender trim on the front ight fender and rear left fender
it was quoted to be fixed for 975!!! when a fender costs 99 and wheel arch 24.99
what should i do?
Old 11-03-2008, 07:46 PM
thought about fender flares?
Old 11-03-2008, 07:54 PM
Shade tree mechanic
i have the same problem, i will be getting the cutout bushwackers eventually
Old 11-03-2008, 07:56 PM
I LOVE Arizona...
Old 11-03-2008, 07:58 PM
Shade tree mechanic
Originally Posted by CR&C View Post
I LOVE Arizona...
not much rust problems down there huh?
Old 11-03-2008, 08:00 PM
duct tape & zip ties
500 dollars for bushwacker cut out flares. Cut the fenderwells and install the fenderflares. Rust is gone and cost half the amount.
Old 11-03-2008, 08:01 PM
None, Even my 71 Suburban has ZERO rust.
Old 11-03-2008, 08:03 PM
Shade tree mechanic
and more room for tires
Old 11-04-2008, 03:35 AM
Originally Posted by z250kid View Post
what should i do?
Buy a fender, take it to a shop & have it painted and install it yourself.
The thing you have to remember with these older trucks is, if you can't do most of the work & maintainence yourself, you'll end up having so much money tied up in them that you'll never to able to re-coupe what you've spent.
IMO,.....if you can't work on them, then you're better off getting a new model, as in the long run you'll be money ahead.
Old 11-04-2008, 02:48 PM
yea the fender was only 99 dollars on fender to fix the rust cost 475
i just have to get a spot welder removal tool and a spot welder but for now im cutting it out and fiberglass then bondo to hold over til spring fresh paint in winter on sandy roads aint good.
are these bushwackers watertight like sealed?
