Performance Upgrade assistance please! - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-02-2008, 04:36 PM Thread Starter
kylev90's Avatar
Quoted: 4 Post(s)
I need a starter list to get me to 400hp. What stage injectors, turbo, what mods can i do to my existing parts. Fuel mods as well. I'm new and not sure of the fancy lingo. Talk to me dumb please! sorry to
I have exhaust, air filter, southbend clutch kit.
1997 CC SB. Stage 1s, 17*hpop, S&B CAI. 4" straight pipe, TW tunes, zf5 swap
kylev90 is offline
post #2 of 7 Old 11-02-2008, 04:50 PM
Send a message via AIM to kx592
SD fuel pump/oil pump....stage III injectors...TW chip...DIY intake....
someone else can pitch in on turbos..im not familiar with many
1997 7.3 extended cab 8ft.
4" straight piped
DIY intake- 6637 filter
178K on the dash
Boost, PYRO, Trans temp gauges (auto meter)
33" nittos on stock height
kx592 is offline
post #3 of 7 Old 11-03-2008, 01:06 AM
you forgot to replace the exaust from the turbo back.
99 F350 CCLB 67k miles.
Sold: 01 Dodge cummins ECLB a few more mods to 353hp
Sold: 97 F250 SCLB, 5 speed 2wd. minor mods to 327hp
See a pattern? next I will have to find one of those 6 door jobbers...
Big Bird is offline
post #4 of 7 Old 11-03-2008, 04:37 AM
Ole White
bigwhite7.3stroker's Avatar
*17 HPOP(High Pressure Oil Pump), Stg II's will make 400 but if you got a little extra $$ Stg III Hybirds which will be good for 500 hp with supporting mods
As far as a Turbo the D-66 from Beans Diesel will be good for 400 but if you plan to go bigger in the future do a Modded H2E
4 inch exhaust, TW or DP Custom Tuned Chip, Gauges, DIY Intake
Supporting Mods not neccessarily needed for 400hp but will be needed beyond 400 are Regulated Return Fuel System and FASS Fuel Pump
Looking for 05-07 front end with Harley Lights
bigwhite7.3stroker is offline
post #5 of 7 Old 11-03-2008, 10:19 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
430HP with my mods on the '95
Cary
CT Performance, Inc. is offline
post #6 of 7 Old 11-03-2008, 04:45 PM Thread Starter
kylev90's Avatar
Quoted: 4 Post(s)
mods
I am definitely doing downpipe back with four inch. Will I have to do head studs no matter the stage injectors? Intake is on its way. I was also looking into injectors and am confused as to how they can rebuild my stock to build so much more HP while still using original tips? Thank you all for your help. Im ready to get starting just having trouble knowing where to begin.
kylev90 is offline
post #7 of 7 Old 11-03-2008, 05:02 PM
1badpsd's Avatar
head studs really aren't need till close to 500hp and they only use your stock injector nozzles on stage 1's
Caylon Golden24
[B]01' F-350[B] ccsb dually 4x4 BTS
S475,300/200,SRP 1.1,h11's, DI headers and a few other parts
01' F-350cclb single wheel swap 4x4 "tow hoe" 250/200's, modded h2e, SRP 1.1, headers
00' f-250scsd 695.8hp
1badpsd is offline
