Oil leak on Back side of engine - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-19-2014, 09:07 PM Thread Starter
1997 OBS 7.3L.
I have a oil leak down the back side of my engine. I checked for oil on the front side of my engine and didn't see any. It all runs down the back and blows all over the oil reservoir and the qorque converter cover plate. If it is coming from the back of the engine, does that narrow it down to the EBPV or is there other stuff back there?
tucker0104 is offline
post #2 of 4 Old 02-20-2014, 03:58 AM
over thinking everything
fordmandan87's Avatar
Quoted: 3 Post(s)
There is a drain in that area of the valley I would do my best to clean all the oil up and look for a source
97 F-250 CCSB 4x4 7.3 E40D 305,000 miles 285/75/16 Cooper Discoverer at3s' diy 6637 intake diamond eye 4in stainless turbo back straight pipe auto meter pyro, trans temp and boost gages on triple a pillar pod baby swamps and php hydra chip - paid off 335hp 704tq
currently getting 12.5 mpg hwy
Originally Posted by 351fifty View Post
Don't mind JJ, he lives near Santa, but uses a powerstroke instead of reindeer
fordmandan87 is offline
post #3 of 4 Old 02-20-2014, 11:39 AM
Micko's Avatar
Quoted: 4 Post(s)
If the vally is dry, check out the oil rail end plugs
Micko is offline
post #4 of 4 Old 02-20-2014, 04:19 PM
kctyphoon's Avatar
more than likely its from the exhaust back pressure valve.. its a very common leak. search youtube and there will be some videos showing you how to repair it, or you can just ignore it since its a pain to do and it wont hurt anything if you decide to leave it. there are other possible leaks, but this one is widely known as the "most common" leak at the rear of the valley.
kctyphoon is offline
