Pulling cyl heads - Ford Powerstroke Diesel Forum
Old 11-01-2008, 09:00 PM
Pulling cyl heads
So I figured I'd pull the cyl heads on the donor motor I have to go into my truck. I was just going to throw it in but figured to at least pull the heads and inspect, and have a vac test done on the heads to see if the vlaves are sealing properly. I figured while I have in injectors out I'd replace the seals. Anything else to do?
Thanks
Will
Old 11-02-2008, 03:17 AM
replace the glow plugs if there bad or not if you have the heads off then do it because there a pain and you dont have to worry about the probe falling in the cylinder
Old 11-02-2008, 08:35 AM
Thanks, ya I was thinking of doing that as well.
Is there anything I can check on the injectors to see if they are still good?
