HELP ANY IDEAS WELCOME 1997 7.3 wont start - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-19-2014, 03:19 PM Thread Starter
Batt were dead so I charged them a bit and tried it every time it almost started and batt die, truck sat for a month in cold weather have never had issues starting it b4......messed with it here and there would not quite fire just spit and sput, checked filter its full, CPS is 2 months old, seems like the injectors are not firing fuel in as I sprayed just a tad of starting fluid in and it chugged from the fluid was all......however when hooking up charger at one time I for a split second had cables backwards.........checked all fuses in truck nothing blown but just turns over and nothing even pops.....any help be great thanks.
Racetech19 is offline
post #2 of 6 Old 02-20-2014, 11:02 AM
the baconator
terryknight's Avatar
Quoted: 149 Post(s)
plug it in and make sure the (might want to get them load tested) are fully charged. after that does it spin over fast? is there any smoke from the exhaust?
if the batteries are bad they should be replaced in pairs
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #3 of 6 Old 02-20-2014, 11:13 AM Thread Starter
Yes I did a load check on them there good and now fully charged spins over fine no smoke like the injectors are not powering up.......starting to wonder if I smoked the CDI box
post #4 of 6 Old 02-20-2014, 02:51 PM
dazed01's Avatar
I've known people to fry PCM's on vehicles when they hooked the battery up backwards. No idea if that will happen on this vehicle or not though.
Gun control is like trying to reduce drunk driving by making it tougher for sober people to own cars.
dazed01 is offline
post #5 of 6 Old 02-20-2014, 03:34 PM
kctyphoon's Avatar
people will scream at me for suggesting this - the engine needs to spin at a minimum rpm in order for the pcm to allow it to start, so be sure the batteries are up to snuff. first thing is check all your fuses. if good, then check your oil level. if good, check to see if there is fuel in the bowl. if there is, drain it, and crank the engine again - check to see if it filled. if it did, you know your pump works, and you are getting fuel at least that far. you know your engine is getting air - so then its down to high pressure oil, fuel to the injectors, or a sensor of some type.
what "i" would do - is disconnect the power to the glow plug relay and try spraying a small amount of WD40, or starting fluid. some people will act like im telling you to throw a grenade in your motor but its hardly as bad as some people make it out to be. the key is disconnecting the glow plugss. anyway - if the engine turns over - you know its a fuel issue, if not - high pressure oil, or sensor. it could be a few different things but this will narrow it down assuming your pcm and other major electronics are good. you may just need to pump some fuel through the system and purge some air if its been sitting for while and you didnt have an issue before.
kctyphoon is offline
post #6 of 6 Old 02-24-2014, 05:31 AM
PhilMac's Avatar
I agree with everything kctyphoon said. Is your wait to start light coming on? its controlled by the PCM usually if it comes on its ok. Also check to see if theres oil in the HPOP resivoir.
'97 F-350 7.3 CCLB SRW ZF5 4x4
360,000+ miles
South Bend Stage 1
DP-Tuner - 40T,80T,80E,100P
Boost & EGT Gauge
DE 3" DP & 5" Exhaust
DIY 6637
PhilMac is offline
