GPR - Ford Powerstroke Diesel Forum
post #1 of 8 Old 11-01-2008, 08:05 PM Thread Starter
ZachBoyer's Avatar
GPR
So I think my GPR is going out. I put a voltemeter on the terminals and i read 10 and 11 volts when i turned my key on. Is that meaning a bad GPR???
2005 F250 6.0 King Ranch Crew Cab Short Bed 4X4
-MODS-
4" Turbo Back Straight Pipe
Sinister EGR Delete
Sinister Coolant Filter
Cat EC-1 Coolant
ZachBoyer is offline
post #2 of 8 Old 11-02-2008, 04:15 AM
z250kid's Avatar
wich side are both sides reading that because on side on my old one read 12.75
and when i turned the key the other said less then a volt so i relaced it and no it reads about 11.50 volts
1996 F350 4x4 Powerstroke Diesel
Afe Stage 2
3 Inch Downpipe,Cat-Delete,90 degree elbow(ss)
Diy Exhust Brake
Hpx Crossover
z250kid is offline
post #3 of 8 Old 11-02-2008, 07:45 AM
Powerstroke Techie
alabamafrog's Avatar
Read between the two big terminals. It should read les than 0.5 volts, if more than that the GPR is bad. The 10v to ground could be batteries or weak GPR or bad connections.
“Government, even in its best state, is but a necessary evil; in its worst state, an intolerable one” (T Paine)
Government cannot give anyone anything without stealing it from someone else. (A Frog)
alabamafrog is offline
post #4 of 8 Old 11-02-2008, 07:51 AM
97 golden stroker's Avatar
what are your batterys at?
97
afe intake
ats intercooler
3in. down pipe to 4in str8
fpr shim
terminator hpop
warm up valve delete
tw 6 position
southbend clutch
Stage ones from Rosewood diesel
SD IDM
d66
12000k hid dual element
thinking real hard about a nozzle upgrade
220k
97 golden stroker is offline
post #5 of 8 Old 11-02-2008, 09:44 AM Thread Starter
ZachBoyer's Avatar
batteries are at 13.75. The two big terminals are the same voltage key on or off. The two small terminals are 0 on off and 10 and 11 on
-MODS-
Sinister EGR Delete
Cat EC-1 Coolant
post #6 of 8 Old 11-03-2008, 05:08 PM Thread Starter
ZachBoyer's Avatar
BUMP BUMP BUMP
-MODS-
Sinister EGR Delete
Cat EC-1 Coolant
post #7 of 8 Old 11-03-2008, 06:19 PM
Powerstroke Techie
Key off one big terminal should be 13.75 to ground the other should be 0.
Key on both big terminals should be the same to ground but near 0 between each other.
As for the little ones, one should be always hot and the other is grounded by the computer when it wants the plugs to be on.
post #8 of 8 Old 11-04-2008, 12:56 PM Thread Starter
ZachBoyer's Avatar
so my method by testing the two big ones together and then the two small ones together doesnt work?
-MODS-
Sinister EGR Delete
Cat EC-1 Coolant
