94 F-series Super Duty - Ford Powerstroke Diesel Forum
Old 11-01-2008, 04:18 AM
I friend of mine has a 94 superduty it is a roll back TT.
Do you guys know if they came with block heaters??
Old 11-01-2008, 05:29 AM
Should be on the right side facing the grill inside the lower right hole in the grill.
Old 11-01-2008, 05:31 AM
It could have one. Look for the plug end inside the engine bay near the drivers side headlight. It's usually coiled up and zip tied there. Also you can look underneath right near the oil filter to see if the block heater itself is installed on the truck.
Old 11-01-2008, 05:35 AM
If its got one it will be between the grill and header support. On the right with wire loom around to and a plug cap on it if it hasnt been taken off.
