wild fuel pressure 110+ psi pulses - Ford Powerstroke Diesel Forum
post #1 of 2 Old 02-17-2014, 01:56 PM Thread Starter
Nitro41's Avatar
I wanted to check my fuel pressure on my truck a couple of times, and tried diffrent gauges because I feel its down on power. I plug it onto the schrader, and the needle rapidly swings from 20-100psi at like mach 5. If I bring the revs up, it gets even worse and just pins the gauge out. Swingin wild like 20-110+
Original fuel pump, bowl heater disconnected, water in fuel disconnected, filter minder disconnected.
I heard its supposed to sway a bit being a mechanical pump, but theres no way to read this thing!
97 Single Cab F250 4x4 5 speed
Swapped D-60
Locked front and rear
160 sticks
Wildman Tunes
Hood Stack
OFE clutch
T500 HPOP
Linex rockers
35" MTR Kevlars
and a bunch more...
Nitro41 is offline
post #2 of 2 Old 02-17-2014, 03:07 PM
midnite rider's Avatar
Quoted: 285 Post(s)
You neen a snubber valve in the line to stop the fuel spikes.
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
