Painting the dash - Ford Powerstroke Diesel Forum
post #1 of 2 Old 02-16-2014, 03:42 PM Thread Starter
HOYBOY's Avatar
Painting the dash
So from the pictures you're about to see lotion got spilled on the dash of this truck while having transmission work done set up mechanics place for 6 months in the Sun and f'ed up the paint on the dash and while cleaning it it took off the paint so where is the best place to get touch up spray paint for the dash it's the deep red color
Sent from my DROID RAZR HD
ID:	244330   Click image for larger version
SLOW STROKIN
2006 6.0 Amarillo
95 Ford F250 4x4 7.3 blue Charlene (sold)
94.5 Ford F250 4x4 7.3 Green two-tone Tracy (junked)
HOYBOY is offline
post #2 of 2 Old 02-16-2014, 06:42 PM
Quoted: 9 Post(s)
I went down to my local auto body supply store and they mixed up some exact match color of interior plastic specialty paint. I just got it in a pint can and used my regular HPLV paint sprayer to apply it straight out of the can but they could put it into a rattle can for a extra cost. It is all a matter of how well you clean the parts as to how it will look when finished. Clean with clean dye and perfume free dish soap (Dawn works for me) and a scrub brush. Then rinse with some clean water. I thin took some plastic prep that was matched to the paint system I was using and wiped it down. Then I sprayed 3 coats. One semi dry followed by 2 wet coats with about 5 min between coats. It looked good and has held up well.
1997 Crew Cab Long Bed 4X4 (DRW Conversion) Auto. 280K miles
Stainless Irate Bellowed Up Pipes
Fresh Turbo with 1.0 Housing & Wicked Wheel II, 3" downpipe with 4" exhaust, Intercooled, 6.0 Fan, 39 gal rear fuel tank + 70 gal Transfer Flow in the bed, Hydroboost, Completely New Suspension (Springs, Shocks, Bushings),08 Rear Diff Cover, Baby Swamps, Hydra Chip with Swamps Tunes, and Swamps IDM, Dually Swap, Tru-Trac locker in the rear, Red Head Steering Box and Borgeson Steering Shaft
ChallengerRV is offline
