Oil Cooler question??? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 02-15-2014, 03:11 PM Thread Starter
I just rebuilt my oil cooler with new orings and gaskets.
While cleaning everything I mixed up which end went on what end of the cooler.
Looks to be reversible, so I re-assembled with a tab in the center of the allingnment mark and bolted back on.
Any thoughts?
clint_ives is offline
post #2 of 9 Old 02-16-2014, 05:53 AM Thread Starter
Nothing?...............
post #3 of 9 Old 02-16-2014, 07:02 AM
PSDTV21's Avatar
It works either direction. As long as its lined up properly you should be fine
Sent from AutoGuide.com App
-Tyler
1994.5
Efuel, Valair 500hp, D60, Hydra w/PHP tunes
PSDTV21 is offline
post #4 of 9 Old 02-16-2014, 07:20 AM Thread Starter
By lined up I assume you mean each end matching so it bolts to the block flush?
post #5 of 9 Old 02-16-2014, 03:26 PM
PSDTV21's Avatar
Yes. If they are a little off the bolts will correct it but they need to close to start with
-Tyler
1994.5
PSDTV21 is offline
post #6 of 9 Old 02-16-2014, 03:34 PM Thread Starter
I got it back on the block without any trouble.
The cooler tube has tabs on each end about 30 degrees off from one another.
Using the tabs there's only 2 ways each end can go.
I was just worried that the tube itself might not be reversible.
post #7 of 9 Old 02-16-2014, 03:38 PM
PSDTV21's Avatar
Should be alright. It looks the same forward and backward
-Tyler
1994.5
PSDTV21 is offline
post #8 of 9 Old 02-16-2014, 03:39 PM Thread Starter
Thanks for the help.
post #9 of 9 Old 02-16-2014, 03:40 PM
PSDTV21's Avatar
No problem man
-Tyler
1994.5
PSDTV21 is offline
