What IZZIT? - Ford Powerstroke Diesel Forum
Old 10-29-2008, 11:06 AM
What IZZIT?
I recently picked up a 96' E350, 7.3 PS Quigley 4x4 conversion and this thing is mounted to the inside engine cover. The switch on the left says ON-Off and the thing simply tells me my RPM and voltage. I can't get it to do anything else. The photo is of the thing "booting" and shows other features that don't seem to be available or working. I can control the engine idle RPM with it but other than that I'm lost.
The buttons above control my lights.
http://www.powerstroke.org/forum/att...1&d=1225307019
Any ideas?
Thanks!
Slam
Old 10-29-2008, 11:09 AM
Thats Mr. Oil Leak.....
it is a factory box for controlling idle. You can use that to adjust your idle for engine warm up / pto operation / or to keep alternator output up for ambulance's etc...
Old 10-29-2008, 11:14 AM
Wow... That was fast!
Any point in leaving it in? It looks kinda klutzy and sits right under the cup holder.
I plan to rechip the engine and add a proper intake system so I figure I'll pick up some control over those functions anyway.
Thanks again
Slam
Old 10-29-2008, 11:17 AM
well, here is a for ya
I have never seen one of them there thingy majiggers myself though
Old 10-29-2008, 11:18 AM
4x4 diesel van awsome. What are youre plans ? I have always wanted a 4x4 diesel van.
Old 10-29-2008, 11:19 AM
If your new chip has a "high idle" setting then no there is no reason to keep it.
BTW
Old 10-29-2008, 12:14 PM
Thanks for the kind welcome folks!
I've been reading the forum for some time and I gotta say that some fine, knowledgeable folks hang out here! I plan to become a paying member shortly.
As for plans... She already has a 12" lift, gas shocks, 39.5 swampers, lockers, 12k Marker winch, 8 KC lights, rack and more. At this point I plan to do the maintenance the other owner failed to do and let that engine BREATHE to a new pacemaker. I'm also gonna change the tires down to a 36-37" with a roadworthy tread. It sounds like a buzz saw in there.
This is my 4th 4x4 van but first diesel van. They are great vehicles for almost everything. I built the first 3 vans but this one came with the Quigley mods which is fine with me.
For the last 8 years I've been driving my Hummer H1 and getting tired of the constant upkeep, small space and limited passenger room. Last year we tried to be the first to break into Bear Valley Idaho at the end of the winter in the H1 but didn't make it. Fortunately it had front and rear hydraulic winches or it would still be there. My last 4x4 Van (gasser 460) had zero problems getting in. Sort of a badge of honor hereabouts.
I picked her up in Houston and drove back to Idaho last week and on the first stretch I hit almost 14mpg but I decided to have the oil changed and check the air filters. The air filters looked like they had been soaked in tar so I replaced them and the oil and so forth then hit the road again expecting an increase....
Mileage dropped to 11. Weird.... Very little change in driving habits along the way. I was hoping this "box" was some sort of ancient chipper that I'd screwed up somehow but guess not. I'll just leave it turned off.
http://www.powerstroke.org/forum/att...1&d=1225310808
http://www.powerstroke.org/forum/att...1&d=1225311059
Any suggestions for a controller? I've got a few thoughts based on what I've read here.
Slam
Old 10-29-2008, 01:07 PM
That thing is cool. Does it have a dana 60 in the front?
Old 10-29-2008, 01:20 PM
definatly smaller tires. But that is the best van i have ever seen. Growing up i wanted the lunch box remote control.
Old 10-29-2008, 01:21 PM
I would get a TW or DP chip
