7.3 died in driveway - Ford Powerstroke Diesel Forum
post #1 of 10 Old 02-14-2014, 02:02 PM Thread Starter
7.3 died in driveway now has no power anywhere no lights, won't turn over, no radio, no nothing. Dome light is one when door is open when you turn key on dome light goes very dim. Any ideas? bad ignition? when it died i couldn't turn it off with the key. batteries are good and no blown fuses.
ziob is offline
post #2 of 10 Old 02-14-2014, 02:15 PM
TRUKK30's Avatar
Make sure you check all the grounds from the batteries to the engine/frame. If you haven't done so already maybe have the batteries load tested?
TRUKK30 is offline
post #3 of 10 Old 02-14-2014, 02:46 PM Thread Starter
gonna clean and check tomorrow they were fine......tried turning it off with the key it wouldn't then it just died on its own. no power no lights no radio won't start now dead where it sits. As soon as you turn the key past acc to start it dome light goes almost dead.
ziob is offline
post #4 of 10 Old 02-14-2014, 03:04 PM
Quoted: 47 Post(s)
Automatic or manual transmission?
When you turn the key to RUN, does the WTS light come on for the usual amount of time?
madpogue is offline
post #5 of 10 Old 02-15-2014, 06:19 AM Thread Starter
manual, can't even get starter solenoid to click, put light switch on nothing....only thing that shows up on dash is the 4x4 light and my dome light is on until i turn the key all the way on....outside of that nothing works signals, radio, nothing.
ziob is offline
post #6 of 10 Old 02-15-2014, 08:06 AM
Quoted: 47 Post(s)
If the WTS light doesn't come on, and given what happened trying to shut it down, I'd say either the ignition switch is bad, or the actuator that connects the key cylinder to the ignition switch is out of whack.
Dome light shouldn't go on at all, though. Check to make sure the dimmer adjustment on the headlight switch isn't cranked over past the click stop for the dome light.
Test - PUT THE TRUCK IN NEUTRAL (so you don't run yourself over), key out, put a jumper between the two big terminals on the starter relay. If the starter cranks, then your batteries and starter are good. Or, alternately, put a small jump wire from the battery + to the small terminal on the starter relay. Then if it cranks, then you know it's all good, including the relay.
madpogue is offline
post #7 of 10 Old 02-15-2014, 08:50 AM Thread Starter
dome light comes on if the door is open...i'll check the starter that way as well. If it is all good i guess i'm looking at a bad ignition? But would that explain why the lights won't even come on?
ziob is offline
post #8 of 10 Old 02-15-2014, 08:58 AM
Quoted: 47 Post(s)
You mean the headlights don't work? "Lights" doesn't tell us much.
madpogue is offline
post #9 of 10 Old 02-15-2014, 09:04 AM Thread Starter
my bad yes no headlights, no signal lights, no nothing...headlights should come on even with key off and they don't
ziob is offline
post #10 of 10 Old 02-15-2014, 10:58 AM Thread Starter
starter and starter relay were good put direct power to relay and it whipped over........battery grounds were good then i look at a ground driverside firewall is melted to ****.....turns out this is the headlights i pinched it together and lights came on....is this a main wire harness ground or something that would affect the ignition, starter, etc? If so i just have to fix it and i should be good pending i find and fix whatever caused it.
ziob is offline
