Dana 60 King pin vs ball joint - Ford Powerstroke Diesel Forum
post #1 of 10 Old 02-13-2014, 05:24 PM Thread Starter
RedNeckMetalTruck's Avatar
Hello all. I am looking to swap a dana 60 into my 1996 F250 PSD.
I am not worried about doing the swap, I have the tools and facility. However I am trying to figure out the pros and cons of either a king pin or ball joint. From what I have read it looks like the ball joint ones tend to have better road manners and are easier to service. Conversely the king pin is more durable but a little hard to work on. I don't mind if its easy to service or not. Thats just part of owning an OBS. I also feel that if you're worried about the road manners of a 18 year old solid axle truck.... then you shouldn't be driving an 18 year old solid axle truck.
I use the truck as a daily driver and frequent towing for work. The truck makes constant trips to Tahoe and camping. I also plan on keeping the truck forever.
Just in case it doesn't show up in my signature here are the stats:
1996 EXT cab long bed
PSD 4x4 auto
116,000 miles
140v mod
DIY intake with AFe "Big Boost" filter
4.10's
3in down pipe, 4in straight out dumped in front of the axle
Triple disc tranny
Future plans, any input would be appreciated:
Injectors
Tuner
D60 (obviously)
'Merica
Ben
1996 F250 4x4 auto
Arrest me Red.
7.3 PSD ext cab long bed.
DIY intake AFe Big Boost filter
3 inch DP to 4 straight out
approx 141,000 miles
TW 6 POS chip
140v mod
33/12.5/17 Nitto Mudders
4.10's
Cobra 49, 6ft Firestik
RedNeckMetalTruck is offline
post #2 of 10 Old 02-13-2014, 07:31 PM
I like the kingpin as I had two on '90 and 91 F350 diesels logged many miles just greased that's it. Ball joints two trucks 96 and 97 you'll have to replace them but still very durable. I prefer the ball joints axle only because they come with the non slide pin brake caliper to bracket set up. The kingpin brakes with the slide pins are a royal pain in the but. Would be idea to have KP with the slide bolt (like on 97) set up.
jrc
'97 Red F250 CC XLT ZF5 3:55s, Dana 60, SD springs all round, 'jectors, IC, 6.0 fan, TW files, VisionX lights and other stuff.
'96 White/Silver F250 SCSB 4X2 (all stock for now)... 4:10's E4OD.
jcart is offline
post #3 of 10 Old 02-13-2014, 07:36 PM
Sam Burton's Avatar
I figures its all about what you can find for what price.
I have run both and really don't notice any difference in driving them.
the king pins last longer and are stronger but more expensive to rebuild.
ball joints aren't as strong but cheaper to replace, that being said I have never broke a ball joint and I am very hard on my stuff.
1978 Ford Bronco
12v Cummins
ZF-5 NP 205 10.25 rear Dana 60 front
Denny T fuel pin 366 governor spring
HX 35 turbo BD exhaust brake
Powerstroke intercooler
1990 F-350 Crew-Cab Short Box XLT 4x4
Powerstroke E4OD
170cc stage 1 injectors, superduty intercooler, flowmaster 3" down pipe, 4" exhaust, 6637 filter, 17* HPOP, Wildman tunes, build E4OD, 5 disc billet converter, Irate E-fuel, 1.0 exhaust housing, WW2, CCV mod, homemade RSK
Sam Burton is offline
post #4 of 10 Old 02-13-2014, 07:47 PM Thread Starter
Thanks for the replies.
So I am assuming that the brakes from my Dana 50 will not swap over to the kingpin axle?
Ben
1996 F250 4x4 auto
Arrest me Red.
TW 6 POS chip
140v mod
4.10's
post #5 of 10 Old 02-13-2014, 07:50 PM
Sam Burton's Avatar
I doubt it.
1978 Ford Bronco
12v Cummins
Powerstroke E4OD
post #6 of 10 Old 02-13-2014, 07:53 PM Thread Starter
Got it. I think I am still a little impartial to either one. Might just see what I can find for the best price. From what I have seen so far most complete axles are running around 900-1200.
Ben
1996 F250 4x4 auto
Arrest me Red.
TW 6 POS chip
140v mod
4.10's
post #7 of 10 Old 02-14-2014, 04:38 AM
ZMANN's Avatar
Quoted: 1596 Post(s)
I think Ford didn't do us a Favor when they had Dana take out the King pin and use ball joints like in a Dana 44
then to call it a super 60
We Miss you Ronnie
ZMANN is online now
post #8 of 10 Old 02-15-2014, 06:39 AM
m j
1PMD60FKK King Pin Dana 60 rebuild kit - FORD
I didnt see much $ difference between BJ and KP for rebuild cost, the BJ axle under my truck is the first BJd60 I have had
aftermarket parts are a little more hard to come by ie. high steer arms
1997 F250 rclb 4x4, Comp910s, SRP1.1, Irate T4 s468,FullForce 350/200, homebrew efuel with i̶n̶ ̶t̶a̶n̶k̶ ̶a̶e̶r̶o̶m̶o̶t̶i̶v̶e̶ ̶1̶1̶1̶4̶2̶ A1000 5/8" drawstraw, Diesel Innovations fuel rail feed fittings, balljoint D60f Detroit Locker, zf5 sachs K70263-01CB ceramic clutch , Grizzly locker 10.25, 315/75/16 Wrangler MT/Windowed 7.3 Oct 9/14
m j is offline
post #9 of 10 Old 02-15-2014, 07:40 AM
leojr's Avatar
Quoted: 4 Post(s)
I stayed with the ballpoint so I could reuse as much of my D50 brake parts as possible. I've already installed longer brake lines so this is one less thing to slow me down during the swap. Changing brake calipers and bleeding the brakes would have to be done during the swap to a king pin axle.
Just my thoughts...
Denton, TX
I envy those that know exactly which modification to make and in the most logical of sequences. But not enough to trade for my meanderings and misfires.
1996 F250 crew cab/short bed, 4x4, auto PSD, 6637 air filter, interior grab handles, stainless window vents, remote door locks work with engine running mod.
Last edited by leojr; 02-16-2014 at 04:13 AM. Reason: Reference to king pin instead of ball joint
leojr is offline
post #10 of 10 Old 02-15-2014, 05:31 PM
truckyard1's Avatar
Quoted: 18 Post(s)
There's a reason most rock crawlers love the KP axles, that steel pin is strong. That being said, are you going to crawl your diesel? if not get the ball joint axle, your brakes will swap over.
Rob
'95 F350 CCLB, "Project Moneypit", ZF5, 4x4, straight piped, DIY E-fuel, more coming
'63 Jeep Truck, Chevy motor, Ford 9"
truckyard1 is offline
