wont start cold - Ford Powerstroke Diesel Forum
Old 10-28-2008, 04:26 PM
Question wont start cold
I have a 1995 Ford f-350 powerstoke dually. when the temp outside goes below 40, its hard to start. I replaced the glow plugs, fuel pump, and last year i replaced the glow plug relay. i going to try a different one again. any ideas? i heard of a intake heater kit but cant find one, did anyone here of one?
Old 10-28-2008, 08:53 PM
Well if I may throw a suggestion to you I would take a test light and see if you are getting power to the glow plugs and power into the valve cover. I replaced my glow plugs because I thought that was the prob. But I was getting power two 4 of my glowplugs.
Old 10-28-2008, 08:57 PM
block heaters work great, i got one on my 97 f-350 dump, we use it to plow up here in nh and on those weeks of 10* and such, just plug it in and when you want to start it it fires up like a summer day
Old 10-28-2008, 09:16 PM
I love block heater too when in town. But what about whent you out hunt'in. lukiss
Old 10-29-2008, 03:10 AM
thanks, do these fuel bowl heater do anything if not im going to unplug mine. i was told if they were not working properly they would take power from the glow plugs. also i was told of a intake heater kit to do away with the glow plugs has anyone heard of this?
Old 10-29-2008, 01:42 PM
intake heater kit would be ideal!!!
is there such a thing fo obs?
Old 10-29-2008, 01:48 PM
they might have a aftermarket kit but 7.3 did not get a intake heater until late 99.i swapped my early model for a late model so i could get the intake heater they work so well it is amazing the differents it makes to shoot some warm air in the sucker were i live in colorado you have to have all the cold start aids you can get not only does it get cold but the elevation is so high you dont have much air.
Old 10-29-2008, 02:03 PM
can anyone let me know if there is anything like that
make eltric bill a lot lower and starting easyer
Old 10-29-2008, 02:23 PM
you could make your own by drilling a hole the size of the intake heater and then just buy a replacement for a 99 to 03 then install the heater get you a relay to run it and hook it up to a switch on your dash then when you want to use it hit the button.
Old 10-29-2008, 03:24 PM
has anyone heard of a High Pressure Oil Crossover Hose?
does it eally work fo cold starting?
heres a website i found
7.3L Ford Powerstroke High Pressure Oil Crossover Hose Kit
