03 SD dana 60 into 96 f250 - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-12-2014, 03:54 PM Thread Starter
I found a someone who has a dana 60 out of SD ready to roll for 550. My questions are:
Can i use OBS 350 springs so i dont have to have a custom bracket fabricated for the longer springs?
Does anyone know how i coukd mount the ttrack bar since its in front not behind?
dieselup89 is offline
post #2 of 8 Old 02-12-2014, 04:15 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Custom mount it, joe put 99-04 sd axles on his obs, but why are you gonna do a front and not the rear too?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 8 Old 02-12-2014, 04:36 PM Thread Starter
Is there much difference? I thought they were both 10.25 sterlings? I was just gonna have the front redrilled
post #4 of 8 Old 02-12-2014, 04:48 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Rear in an sd is 10.50, I suggest changing both to keep it simple, also the sd was not offered in a 3.55 gear set in case you don't have 4.10's
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 8 Old 02-12-2014, 04:51 PM Thread Starter
Touche. Completely forgot about that. Any mods needed to swap in the 10.50?
post #6 of 8 Old 02-12-2014, 05:18 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
They have disk brakes, so hydroboost and f-sd proportioning valve, but bolt up from what I understand, just not as good brakes till upgraded as well
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 8 Old 02-12-2014, 05:22 PM Thread Starter
Hmmm. May just tough it out til i can find/afford an older dana 60
post #8 of 8 Old 02-12-2014, 05:26 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Yeah it's not cost effective for the sd axles unless you get a great deal, Kause you need rims too, but for the pair of axles an obs d60 could be easily had
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
