WTF!!!! Anybody? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-12-2014, 09:04 AM Thread Starter
Quoted: 4 Post(s)
Question WTF!!!! Anybody?
So, I'm sitting at a stop light, the engine has been running for 15-20 minutes on lite traffic roadway at 35- 40 MPH, no chip. The light turns green I step on the peddle and, nothing, just keeps idling at normal speed for 1 to 1 and a half second length of time then takes off like it should have when I stepped on the peddle. What's happening? anybody?
timlsalem is offline
post #2 of 8 Old 02-12-2014, 09:15 AM
jesilvas's Avatar
Quoted: 2 Post(s)
Could be many things. But I would lean toward throttle position sensor.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 8 Old 02-12-2014, 10:52 AM
the baconator
terryknight's Avatar
Quoted: 143 Post(s)
that or the idle validation switch
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #4 of 8 Old 02-12-2014, 11:18 AM
hansel's Avatar
Quoted: 94 Post(s)
TPS would be my first thing too look at
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #5 of 8 Old 02-12-2014, 12:44 PM Thread Starter
Quoted: 4 Post(s)
How do I check the TPS out? 12 volt tester or is it more complicated?
post #6 of 8 Old 02-12-2014, 03:43 PM
I believe you'd have to get it to fail or delay again to see it with a meter. Has the problem re-occured? If not, I'd just swap out the sensor see if it happens again, if not you fixed it, if it does return the sensor, or keep it for a spare.
-Jeremy
darkstardevil26 is offline
post #7 of 8 Old 02-12-2014, 04:35 PM
Chop's Avatar
I would try cleaning the two switches on the pedal assembly first before replacing anything
1996 F250 PSD Crewcab,auto,D 60 swap,3" dp, DIY air 4X4 Centurion
Chop is offline
post #8 of 8 Old 02-12-2014, 04:48 PM
the baconator
Quoted: 143 Post(s)
there is a testing procedure but i do not know it. i think all you need is a multi meter
