Chevy 14 bolt conversion info? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 02-11-2014, 04:12 PM Thread Starter
PSD_rookie's Avatar
Garage
So who on the forum has swapped a Chevy 1 ton 14 bolt axle under their rear end? I've seen BrettMavriK's Centurion Bronco project where he put one under his, but I'm looking for some help on what all mods would be needed. I've got a bad Pinion gear and at the cost of rebuilding my axle I've thought about swapping out/upgrading the rear axle. A local parts yard I've got plenty of stuff from has a 14 bolt with disc brakes and the 14b is known for its strength and it gives me the disc brake conversion.
TOTALED - 95 F250 XLT ECLB 4x4
4" turbo back, DIY tymar, Boost/EGT/Trans temp Gauges, 35/12.5 tires, ZF-5 swap with solid driveshaft, Oh yea, and P-pumped 12 valve swap
97 F350 CCLB 4x4
PSD_rookie is offline
post #2 of 10 Old 02-11-2014, 05:22 PM
the baconator
terryknight's Avatar
Quoted: 148 Post(s)
what gears are in it? what is the spring perch measurement? WMS to WMS?
with disc brakes you may notice lack of stopping power in the rear until you chnage teh proportioning valve or you pump the brakes
why not buy another rear axle? can normally be found for less than 200?
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is online now
post #3 of 10 Old 02-11-2014, 05:33 PM Thread Starter
PSD_rookie's Avatar
Garage
I haven't got a chance to do the measurements on the 14 bolt just yet, and I'd prefer to get another 10.25 rear axle, but everyone around here has either crushed theirs(even the posi) or they want close to $500 for it. Highway robbery for a bare used open axle to me.
97 F350 CCLB 4x4
post #4 of 10 Old 02-11-2014, 05:40 PM
the baconator
Quoted: 148 Post(s)
damn i sold mine for 175. next time i'm getting asking 500. they re scrapping them because no one wants to pay 500
post #5 of 10 Old 02-11-2014, 05:55 PM Thread Starter
PSD_rookie's Avatar
Garage
Yep, I actually gave away a cab and chassis dually rear once, but for a Posi rear $500ish isn't HORRIBLE, but thats for a danged open. If I can get my hands on the C5 axle I'd probably be ok with paying $400 or so.
97 F350 CCLB 4x4
post #6 of 10 Old 02-11-2014, 06:01 PM
the baconator
Quoted: 148 Post(s)
i think it is.
post #7 of 10 Old 02-11-2014, 06:31 PM
Quoted: 83 Post(s)
Feedback Score: 4 reviews
Where are you located? I have a 10.25 I would let go for a reasonable price and I'm sure there are others around.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, 38 Gal rear tank, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #8 of 10 Old 02-11-2014, 06:45 PM Thread Starter
PSD_rookie's Avatar
Garage
I'm out of Spartanburg, SC and the axle is 4.10 and am ready to get my truck back running. I've already dumped $600 in it this last month and its been down that long too.
97 F350 CCLB 4x4
post #9 of 10 Old 02-12-2014, 12:24 PM
over thinking everything
fordmandan87's Avatar
Quoted: 3 Post(s)
I have an extra 10.25 axle that could use a rebuild for 50 bucks if you want it
97 F-250 CCSB 4x4 7.3 E40D 305,000 miles 285/75/16 Cooper Discoverer at3s' diy 6637 intake diamond eye 4in stainless turbo back straight pipe auto meter pyro, trans temp and boost gages on triple a pillar pod baby swamps and php hydra chip - paid off 335hp 704tq
currently getting 12.5 mpg hwy
Originally Posted by 351fifty View Post
Don't mind JJ, he lives near Santa, but uses a powerstroke instead of reindeer
fordmandan87 is offline
post #10 of 10 Old 02-12-2014, 03:42 PM Thread Starter
PSD_rookie's Avatar
Garage
I appreciate it, but I've got the same thing sitting here, just has bad pinion bearing and pinion gear. Just don't feel like messing with it right now.
97 F350 CCLB 4x4
