Valve Cover bolts - Ford Powerstroke Diesel Forum
post #1 of 9 Old 02-11-2014, 05:44 AM Thread Starter
Valve Cover bolts
Does anyone have a part number for the valve cover bolts for a 97 ford f-250 7.3L? I lost two when I was changing my glow plugs. Thanks in advance.
tucker0104 is offline
post #2 of 9 Old 02-11-2014, 06:28 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Called ford? That's where I got my manifold bolts, sorry I'm not much help
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 9 Old 02-11-2014, 07:38 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
It's a bolt guys. Take one of the remaining ones to a hardware store and get some more. Since the torque spec is in Newtons I'd start in the metric bin. Don't pay Ford prices for something made in Mexico.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #4 of 9 Old 02-11-2014, 08:12 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
It's where I got my manifold bolts (grade 10.9)
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 9 Old 02-11-2014, 08:14 AM
the baconator
terryknight's Avatar
Quoted: 146 Post(s)
it's an 8 mm 1.5 pitch bolt.
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #6 of 9 Old 02-11-2014, 08:47 AM
Does anyone know off hand the torque specs and if I should put it a silicone gasket maker or some sort when re-installing the valve covers?
T0RCH3D is offline
post #7 of 9 Old 02-11-2014, 08:57 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
11Nm or 96 Lb-Inch
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
post #8 of 9 Old 02-11-2014, 09:08 AM
Thank you, any permatex or silicone gasket maker needed. Seems like for used some kind of gasket maker from factory
T0RCH3D is offline
post #9 of 9 Old 02-11-2014, 10:38 AM
the baconator
Quoted: 146 Post(s)
no gasket maker needed
