6 position chip Issues Relay FOAB 14b192aa Constantly clicking and truck stalls - Ford Powerstroke Diesel Forum
post #1 of 7 Old 02-10-2014, 06:23 PM Thread Starter
SixOhPowerstroke's Avatar
Quoted: 2 Post(s)
97 Powerstroke 6 Position chip issues.. Installed bully dog 6 position on my truck today started it up, it was loping, it would rev up fine, then idle and die. CEL popped up. Cranked it over no start. Disconnected batteries hooked them back up, fired it up, ran for a few seconds then died. Left key on, relay foab 14b192aa was clicking almost constantly. Hooked up scanner and threw p0603. Whats going on here? Removed chip and all was good again, and relay stopped going off. But i would like to get the chip to work. Trucks a 5 speed
2005 F-350 Reg cab Fx4 - Deleted, updated, bullet proofed. TSD tuned. 18x10 moto metal 962's, 35x12.50 federal mt's, 2'' level, mbrp exhaust, ect, ect. Western Ultra Mount 8' Plow. Money maker/work horse.
SixOhPowerstroke is offline
post #2 of 7 Old 02-10-2014, 06:51 PM Thread Starter
Quoted: 2 Post(s)
Just checked this is the PCM Power relay going off.
post #3 of 7 Old 02-10-2014, 08:13 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Sounds like a bad chip
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 7 Old 02-11-2014, 09:19 AM
the baconator
terryknight's Avatar
Quoted: 141 Post(s)
i agree with kris on this one
603 keep live memory. just means the batteries were unhooked
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #5 of 7 Old 02-11-2014, 09:29 AM
Raul@Stealth Automotive's Avatar
did you buy the chip new? if you bought it used is it specifically for your PCM?
Raul@Stealth Automotive is offline
post #6 of 7 Old 02-11-2014, 07:28 PM Thread Starter
Quoted: 2 Post(s)
Came with the truck. Used but not installed. There is something up with the switch though, it will click 10 times instead of 5 times clockwise. Chip looks to be fine, says SUT TDE1 which is for an obs after looking that up. I can try cleaning the pcm contacts a little better and getting a new switch
post #7 of 7 Old 02-13-2014, 10:26 PM
desertdeer's Avatar
PCM contacts have to be totally clean. Be careful though it is easy to scrub the terminals right off of the board. If it isnt a bad connection it could be the chip is burned for the wrong pcm code. In my experience bully dog chips are usually not too picky what the pcm code is as long as it is burned for an auto or manual trans. The switch should have a ring that you place in a slot to control how many positions the switch will have. 6 pos should click 5 times. Hope that is helpful
96 F250 PSD 3''DP 4'' ATS EXHAUST 6637 TS-6 5-SPEED LUK CONVERSION INTERCOOLER PROPANE 4'' LIFT 35X18'S
desertdeer is offline
