Help with 97 f350 idm swap.... - Ford Powerstroke Diesel Forum
Old 10-26-2008, 12:15 AM
ok heres my question, I have a 1997 F-350 7.3L Powerstroke turbo diesel and recently it shut off and would only turn over but not actually crank. I had it tested and the problem came in the form of liquid and corrosion in the IDM so I started looking around for one at a somewhat decent price and the company i ended up getting an idm from demanded my VIN yr model and actual mileage to ensure they got the correct unit to me. Also they wanted the part number off the existing idm and i gave them everything they asked for.
This is the actual info from the idm which is bad
IDM-110
F7TF-12B599-AG
and this is the one they sent me
IDM-100
F6TF-12B599-AA
Will the replacement unit work on my truck as i found that the numbers on the repl.unit are from a 94-e-250 van and my truck is a f350 psd?
the place i got from said it was only a voltage drop that i would never notice and that it would work. Im 2hrs from my truck and i want this to be a 1 trip fix. I dont want to try it as they suggested bc if it doesnt work or if it may cause issues later on then i would rather exchange it and just wait. I have made to many trips for nothing. Any help would be appreciated. Thanks
Old 10-26-2008, 01:56 AM
Shaking the Bush Boss
I dont know if it will work or not. I swapped mine with one from a 2002 f350.
Old 10-26-2008, 05:35 AM
Yes it well work, but i would change it for a higher voltage one if you can.A higher voltage IDM well make it responde better in the lower RPMs.
Old 10-26-2008, 08:48 AM
thanks
i will try and get at least the idm-110 to go back in it.
Old 10-26-2008, 01:47 PM
If anything they should have sent you a newer one like an IDM-120. I would be sending it back unless you got a steal of a deal on it then go replace the resistor so you get 140 volts.
