'96 f-250 died , now wont start????? HELP - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-10-2014, 10:32 AM Thread Starter
On my way to work this morning and as I was coming off a major highway off ramp to enter another highway truck started to buck a few times then once I was starting to accelerate on to the new highway the engine died and wont restart. Had it towed home. I was thinking it maybe the cam positions sensor , but I noticed that when I turn the key on the Wait to Start light does not come on at all. Which is a first. I did change the cam position sensor , but that was not the problem. I read that the WAIT TO START LIGHT is fed from the PCM , could the PCM be bad ,? how do I check it . I noticed that The truck would buck on occasion over the month or so. But other then that the truck runs great with 217,000 mi. on it. Also I did change the glow plugs , glow plug solenoid, and new valve cover harness as well back in September.
Abzack is offline
post #2 of 8 Old 02-10-2014, 10:50 AM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
Check your number 22 fues under the hood. Odds are the fuel bowl heater shorted out
Trucks and parts............
kanuck15 is offline
post #3 of 8 Old 02-11-2014, 06:36 AM Thread Starter
You were correct thats what it was.
Abzack is offline
post #4 of 8 Old 02-11-2014, 06:37 AM
kanuck15's Avatar
Quoted: 10 Post(s)
Glad to hear you are going again! Do yourself a favor and clip the wire for the fuel bowl heater and block off the end or else its just going to happen again
kanuck15 is offline
post #5 of 8 Old 02-11-2014, 07:33 AM Thread Starter
Done, will not useing the heater cause other problems with this below freezing weather were having here ? I did replace the whole glow plug system back in Sept. and I do add a fuel additive.
Abzack is offline
post #6 of 8 Old 02-11-2014, 07:48 AM
kanuck15's Avatar
Quoted: 10 Post(s)
You wont have an issue. The fuel bowl heater doesnt work that well from the get go
kanuck15 is offline
post #7 of 8 Old 02-11-2014, 08:09 AM Thread Starter
Thanks For the help!
Abzack is offline
post #8 of 8 Old 02-11-2014, 08:38 AM
kanuck15's Avatar
Quoted: 10 Post(s)
Anytime! thats why we are here
kanuck15 is offline
