07 f350 axle and suspension swap - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-10-2014, 05:30 AM Thread Starter
Chadahootchie's Avatar
I've completed the swap everything came out good so far. I need to find where to buy the correct reaming tool for the pitman arm. I know there like $90. Also what's everyone doing about the brakes going from drum to disc rear. Brakes work just not correctly. Do I get a manually adjustable proportioning valve or is there a correct one to get for the swap.
1997 Ford F350 CC LB 4x4
2007 F350 axle/suspension swap
238/100 Full Force Stage 3 Injectors
H2E Turbo
Fully Built Trans with Triple Disc Billet
Tony Wildman Chip
Superduty IDM
5'' Straight Pipe 7'' custom sideways bed stack
Leveled on 37s
Chadahootchie is offline
post #2 of 11 Old 02-10-2014, 09:45 AM
the baconator
terryknight's Avatar
Quoted: 153 Post(s)
need the valve from a F-SuperDuty or the whole hydroboost system from an F-SD
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #3 of 11 Old 02-10-2014, 11:49 AM Thread Starter
Is the proportioning valve mounted on the master or is on the frame. I'm finding mixed answers
H2E Turbo
Tony Wildman Chip
Superduty IDM
Leveled on 37s
post #4 of 11 Old 02-10-2014, 12:57 PM
the baconator
Quoted: 153 Post(s)
the ABS valve is on the fame, it has been called a proportioning valve. the one your are interested in is on the frame. The F-SD had disc rears and the 07 axle has disc rears, discs require more fluid than drums, the F-SD proportioning valve keeps more fliud going to the rear brakes than the standard valve in 250 and 350s
post #5 of 11 Old 02-10-2014, 03:24 PM Thread Starter
What are the chances of finding one? I called my local dealer and it's $600 plus $100 core charge had non returnable. The guy at the counter was suprised it cost that and figured there going to be obsolete soon since it's such an old truck
H2E Turbo
Tony Wildman Chip
Superduty IDM
Leveled on 37s
post #6 of 11 Old 02-10-2014, 03:38 PM
the baconator
Quoted: 153 Post(s)
auto parts stores sell the MC. i think dorman makes hoses. it is bolt in swap and your get a bigger MC
i think the MC is $100ish w/o cruise 120 with hoses re around $20 a piece. i dn't know what the booster runs. if you are looking for just the proportioning valve i don't know where to find that
post #7 of 11 Old 02-10-2014, 03:43 PM Thread Starter
What ever is going to make my brakes work correctly with out costing an arm and a leg and not having to replace everything under the hood.
H2E Turbo
Tony Wildman Chip
Superduty IDM
Leveled on 37s
post #8 of 11 Old 02-11-2014, 04:02 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
I have done the swap with no brake changes and it works just fine. Peddle is a LITTLE mushy but nothing u do t get used to and it still brakes better anyway
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #9 of 11 Old 02-11-2014, 04:11 PM Thread Starter
Peddle is more mushy for sure and stops ok. I can't really tell to much difference. I feel the rear brakes are hitting at hard as front. The front doesn't dive ever no matter how hard you hit the brakes. The whole truck squats together. Anyone try a manual proportioning valve?
H2E Turbo
Tony Wildman Chip
Superduty IDM
Leveled on 37s
post #10 of 11 Old 02-11-2014, 04:52 PM
ol_Blue97's Avatar
The squat could also be because you are on a radius arm now and not leafs.
Try bleeding out the RABS valve, there is a bleeder on it. It helped my mushy peddle a lot. Air gets trapef in there and it's hard to get out
FRANK THE TANK
