Thermostat. What temp to use? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 02-09-2014, 07:11 AM Thread Starter
sputnik801's Avatar
Quoted: 3 Post(s)
Recently my truck has been running a little cooler than normal. And no - not just because of the COLD east coast temps. Was a balmy 30 the other day and the gauge was low. Heat takes a little longer to warm up as well. Any suggestions of what temp thermostat I should replace it with? The current one was done by my mechanic a while ago when my water pump crapped the bed a few winters ago. Truck is basically stock with no crazy mods. Still runs fine at 377k. Any input is appreciated.
sputnik801 is offline
post #2 of 13 Old 02-09-2014, 08:47 AM
Quoted: 80 Post(s)
Feedback Score: 4 reviews
These engines where designed to use a 203* t-stat. http://www.dieselsite.com/dieselsite203thermostat.aspx
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #3 of 13 Old 02-09-2014, 11:39 AM
Hendricksbus's Avatar
im running a 190*,heats great in the winter months pulls cool in the summer!
96' F250 Ext.cab lb 4x4
stock tires
160K
6 pos chip
Pryo,tranny and boost gauges
fpr shimed, 3'' down pipe,
mods to come: bronco tank, rear shackle flip, sonnax shift kit
Hendricksbus is offline
post #4 of 13 Old 02-09-2014, 12:50 PM
Quoted: 75 Post(s)
I put a 203 in and my mpg's and power have made a great improvement with it.
White95f250 is offline
post #5 of 13 Old 02-10-2014, 07:18 AM
Quoted: 8 Post(s)
I put in a 203* and I do not like it. I did not see any improved power or millage and I have found that now when I am towing 12K in the heat the truck runs too hot for my liking. I can hit 230 - 240 easy pulling a long hill even with my cooling mods. Never had that problem with the 190*. I think the 203 is fine for a DD or a truck that pulls light loads but be aware if you pull heavy in the mountains like I do. I am not saying that it is a bad thing or that it is a bad product. I think it was a quality piece it just didn't work for me. Others have had it work better for them. But, I will be switching back to a 190* once it warms up here.
1997 Crew Cab Long Bed 4X4 (DRW Conversion) Auto. 280K miles
Stainless Irate Bellowed Up Pipes
Fresh Turbo with 1.0 Housing & Wicked Wheel II, 3" downpipe with 4" exhaust, Intercooled, 6.0 Fan, 39 gal rear fuel tank + 70 gal Transfer Flow in the bed, Hydroboost, Completely New Suspension (Springs, Shocks, Bushings),08 Rear Diff Cover, Baby Swamps, Hydra Chip with Swamps Tunes, and Swamps IDM, Dually Swap, Tru-Trac locker in the rear, Red Head Steering Box and Borgeson Steering Shaft
ChallengerRV is offline
post #6 of 13 Old 02-10-2014, 08:19 AM
Quoted: 80 Post(s)
I tow 15k plus in elevations from 1000-10,000 ft on grades up to12%. Try a 6.0 fan, it works very well.
Jack
322000 miles
post #7 of 13 Old 02-10-2014, 09:02 AM
Quoted: 8 Post(s)
I do have a 6.0 fan. Looking at 1Dieselman's mods list compared to mine the big difference is he has injectors and DP tunes. I am running stock injectors with no tune. Maybe that is the reason I run hotter then he does.
post #8 of 13 Old 02-10-2014, 09:07 AM
Quoted: 75 Post(s)
I give you credit for towing that much without tunes. I don't know what I would do without tunes, it's nice going from a regular tow tune to a heavy tow tune when I need it.
Mine stayed just fine on the temp when towing around 8k. But then i'm not towing a load like you guys.
post #9 of 13 Old 02-10-2014, 09:16 AM
Quoted: 8 Post(s)
It does take a long time to get to where I am going
Stage 2 injectors and DP tunes come next month. Just before RV season. I can't wait.
post #10 of 13 Old 02-10-2014, 09:47 AM
Quoted: 80 Post(s)
It's got to be tough towing with no tune's. Keep in mind that more fuel creates more internal heat.
Jack
322000 miles
