95 4x4 7.3 f250 how to prime it? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 02-09-2014, 05:05 AM Thread Starter
Hi, New owner of a 95 f250 ext cab 7.3 150k miles 4x4. Thanks for the great forum...
I bought the truck and after starting it from being parked for 6 months, immediately I noticed a leak apparently from the fuel valve drain.
Si I removed and replaced the fuel bowl for replacing the O rings on the fuel bowl drain valve. The thin O ring on the valve stem was hard like a rock.
How do you prime the fuel system after the bowl has been removed, I had to disconnect every hose that was attached to the bowl. Put a new filter but after this step I don't know how to move forward to get it to start.
Thanks.
Another question I have is if the glow plugs always come on before starting the motor or only when it's cold?
Thanks.
deportes is offline
post #2 of 10 Old 02-09-2014, 05:34 AM
sputnik801's Avatar
Quoted: 3 Post(s)
I've never had an issue re-starting my truck even AFTER fuel pump replacement and bowl removal. Just turn the key to the ON position and wait for your WAIT TO START light to go off. Crank for a few second and it should start up.
I think the glow plugs go on every time. The length they are on depends on the temperature. They should stay on briefly in warm weather and a few seconds in cold....
sputnik801 is offline
post #3 of 10 Old 02-09-2014, 05:55 AM Thread Starter
Thanks for the reply, just wondering where the air goes from the empty bowl. it must go back to the tank I guess!
deportes is offline
post #4 of 10 Old 02-09-2014, 08:03 AM Thread Starter
Truck wont fire up, there is fuel in the bowl, new filter and new batteries.
The glow plug light does not come on at first start, it's 50 degrees outside, should the glow plug be turning on before the motor is turned over? Could it be a glow plug fuse? Any ideas?
Thanks.
deportes is offline
post #5 of 10 Old 02-09-2014, 08:22 AM
midnite rider's Avatar
Quoted: 285 Post(s)
Turn ignition to the on position have someone check to see if there is power to both sides of the relay. If not u can cross both posts with a screwdriver for about 10 to15 seconds, then try to start
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #6 of 10 Old 02-09-2014, 08:29 AM Thread Starter
Found a 40 amp fuse blown in the power dist box. #22 for the glow plugs. Now I need to find a fuse like it.
Thanks.
deportes is offline
post #7 of 10 Old 02-09-2014, 09:24 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
That's the PCM and fuel bowl heater plug too iirc
To prime it, fill bowl with fuel, crank it, purge air at shader valve (valve stem on side of bowl) crank and repeat till it fires up
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #8 of 10 Old 02-09-2014, 09:27 AM
Chop's Avatar
Your fuel heating element has shorted out inside the bowl blowing that fuse .Many either disconnect the wire or in my case cut the element out . The solder joints become loose with the element touching the bowl and Boom .
1996 F250 PSD Crewcab,auto,D 60 swap,3" dp, DIY air 4X4 Centurion
Chop is offline
post #9 of 10 Old 02-09-2014, 09:58 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Moor like pfft, it's just a fuse
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #10 of 10 Old 02-09-2014, 10:01 AM Thread Starter
Ok, thanks. Learning the new truck. Replaced the fuse #22 with a 40AMP. and It turned the glow plugs on for 10 sec and it fired right up. The operators manual shows that it should be a 30AMP fuse. Now that I know it starts I will replace the 40A with a 30A fuse.
The bowl heater looked Ok when I removed it and reinstalled it.
Thanks for all your replies.
deportes is offline
