why does my truck not idle high at start up - Ford Powerstroke Diesel Forum
Old 10-24-2008, 09:53 AM
97 psd, when I start the truck, it just idles at 600-700rpms. wether it is hot or cold, or real damm cold, it does the same thing, so naturally when it is real cold out, it doesnt idle too good for a few minutes. It seems to me, that it should run around 1000 rpms for a few minutes and then drop down, like every other vehicle does. it has been a few years since i have driven a deisel, but if i remeber right, they all idled higher when cold.
I want a high idle kit of some sort, and am looking to get a used ford one, since it is plug and play basically. as of right now, i do not want a chip of any sort, just want to get the bugs out.
Old 10-24-2008, 10:05 AM
North Texas Power Stroke Association - DIY AIC Mod
Here is a mod for really cheap if you are pretty handy.
Old 10-24-2008, 03:25 PM
i found a tsb for 99 and up 7.3's that said that if this occurs and you have no cruise control as an option, that the pcm needs to be reflashed. thats the only info i have found
i do have cruise,
what is invloved with reflashing?
i also saw that an oil temp sensor might be bad?
any ideas?
Old 10-30-2008, 01:47 PM
no else has any ideas?
Old 10-30-2008, 02:22 PM
Powered by Deez Nuts
i havent had my truck that long but when cold it doesnt idle high and i have cruise control.
Old 10-30-2008, 02:33 PM
If my truck sits idaling for a while it atomaticaly idals up.
Old 11-01-2008, 08:37 AM
Send a message via AIM to John_DeereGreen Send a message via Yahoo to John_DeereGreen
I know this thread is a few days old but have you guys checked to see if your EBPV is plugged in? My truck won't go to high idle with it unplugged but plug it in and up she goes.
Old 11-07-2008, 04:18 AM
as far as i know it is, and i think it needs to be cleaned, when its cold its like drive with an exhaust brake. anyone have a picuture of where it is located? i looked but didn t see it
Old 12-22-2008, 06:20 PM
how do you go about cleaning the egpv
ebpv sorry
