Just picked up two used motors - Ford Powerstroke Diesel Forum
Old 10-23-2008, 08:06 PM
Just got 2 used motors today. 7.3L PS 1996 model. One he said is dead, the other is supposed to be a good runner, I'm hoping. I was thinking of going through it, pull heads to start? Anything to look over go through, problem area's???
Thanks guys.
Old 10-23-2008, 08:55 PM
Oh, I found a spec that this engine weigh's 920lbs, I have a 1000lb engine stand. Is it going to be safe on there?
Thanks
Old 10-23-2008, 09:29 PM
International Threat
support it once on stand.
find out what the problem is and fix it!
Old 10-23-2008, 09:31 PM
Send a message via AIM to ford_trck
If you have an engine hoist you can lift it and then block it on the floor untill you get the head off or a few things of high weight
Old 10-23-2008, 10:12 PM
Ya thats what I was thinking. Its sitting on the floor right now. Was thinking of bolting a starter to it and doing a compression test. Can I do it cold? Or should these engines be done warm?
Old 10-24-2008, 06:31 AM
Doesn't matter. What matters is that all of the cylinders are consistent.
Old 10-24-2008, 05:02 PM
Thanks guys.
Will
Old 10-24-2008, 05:30 PM
i saw a post about engine kits bein available but any idea what they run? id love to get my hands on a cheap used motor and tinker with it. long as its got a good block & heads.
Old 10-25-2008, 04:14 PM
Ya, now I have 3 engines. Something to play with. Extra parts, ect ect.
Old 10-25-2008, 04:19 PM
do u have a idm????????
