Glow Plug Relay - Ford Powerstroke Diesel Forum
Old 10-23-2008, 05:09 AM
Send a message via AIM to MTChevy Send a message via MSN to MTChevy
Glow Plug Relay
Is there any negative effects jumping the relay with a hammer? My relay is shot and i cant quite dish out 80 bux for a relay right now. This morning i just turned the key and jumped the 2 big terminals so i could get the darn thing started. cons?
Old 10-23-2008, 01:18 PM
im not quite sure it might screw up the relay
but if its shot then it wont matter
i just replace mine was cracked and had water in it wich burnt it
get it at an internatial dealer for 60$
Old 10-23-2008, 02:25 PM
ebay man they sell for way cheaper then that they have them as cheap as 20 bucks i have ran one for a year now and it still works great that is longer than the ford one worked.there are also heavy duty ones for 60 to 100 bucks depending were you get them.
Old 10-23-2008, 03:15 PM
You can swap the wires on the large terminals. Doing this will cause the voltage to go the other way through the relay. This won't cause any problems. This is just a bandaid, but it will work for a while until you can get a new one. There are many that replaced with a stancor (spelling??). I hope this helps....
