putting a '94/'95 water pump on a '96? - Ford Powerstroke Diesel Forum
Old 10-22-2008, 12:34 PM
ok so i know that in the '94 & '95 engines are a 203/205 degree t-stat, and they do NOT fit in my '96 because its a different water pump.
can I just install a '94/'95 water pump and then get the 203/205 degree t-stats at any parts house then, since i will have converted to a short stem t-stat?
Old 01-27-2009, 07:27 PM
maga bump. same question came up today, i pulled a '95 pump and a '96 pump and only difference i saw was t-stat hole.
how bouts it?
Old 01-30-2009, 06:19 AM
Send a message via AIM to Dieselfever78 Send a message via Yahoo to Dieselfever78
Yes you can interchange them as long as you use the correct thermostat. Also some have a cast inlet elbow and some have bolted, I still haven't figured out which is suppost to have which though. I just know that the bolted elbows can be a PITA to seal.
-Michael
Old 01-30-2009, 07:52 AM
yea the whole point of looking into this was to be able to use the cheap, easy to find 204* t-stat from a '95.
we had a NEW '96 with the bolted one and the REMAN '95 was a cast 1 piece.
Old 01-30-2009, 02:40 PM
I just bought a 203 for my 97 from dieselsite.com. Should I not have??? was around $40 something shipped. seems cheaper then buying a different pump?
Old 01-31-2009, 05:17 PM
i bought one also. it IS cheaper than buying a pump, at first anyway. if you replace the t-stat yearly like recommend then it would only take me 2 and a half years to come out ahead, but thats with my employee cost as well.
